1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Inverting control inputs on SIS3280?
To: [email protected]
Date: Wed, 8 Aug 2018 10:46:13 -0500
Hi all,
I have an SIS3280 that I want to use the inhibit count signal for (this can be done on input 4 in mode 2, for example). Unfortunately,I want to inhibit on a TTL low signal, while my SIS3820 requires an active high inhibit. The SIS3820 does support inverting the control inputs, by setting bit 19 in the Acquisition Operation Mode. I didn't see it as a record in the documentation (http://cars9.uchicago.edu/software/epics/mcaStruck.html). Is there a way to do this from the EPICS driver? If not, is this something that you would consider adding to the driver?
(I could invert the signal externally, but it would be nice to avoid that complication)
Thanks.
- Jesse
Jesse Hopkins, PhD
Beamline Scientist
BioCAT, Sector 18
Advanced Photon Source
Re: Inverting control inputs on SIS3280? Mark Rivers
Prev: Re: Delta Tau motor control problem Kevin Peterson
Next: Re: IOC Crash with No Exception Generated Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Parse a variable-length, multi-column waveform in stream device Abdalla Ahmad
Next: Re: Inverting control inputs on SIS3280? Mark Rivers
ANJ, 14 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
