On 08/14/2018 12:12 PM, Heinz Junkes wrote:
I have a question about bitSets.
I use the example program from exampleCPP get.cpp
with the code fragment
PvaClientGetDataPtr data = pvaClientGet->getData();
BitSetPtr bitSet = data->getChangedBitSet();
Cardinality is "1" although obviously nothing changes.
Bit #0 is set “structure”.
Now to my question. Is bitSet set by the server?
And then I don't understand that either (from the documentation).
"Only fields that change are transmitted.
Only the data for fields that change value between requests are sent.”
That was true for pvaSrv and is still true if you use provider ca
(except for bug shown below).
qsrv changed the semantics.
I am using the latest from the master branch from github for everything.
In one window I start
mrk> pwd
/home/epicsv4/masterCPP/exampleCPP/database/iocBoot/exampleDatabase
mrk> ../../bin/linux-x86_64/exampleDatabase st.cmd
In another window I start:
pwd
/home/epicsv4/masterCPP/exampleCPP/exampleClient
mrk> bin/linux-x86_64/get -p pva -r "value" DBRdouble
provider pva channelName PVRdouble request value debug false
_____get starting__
Type exit to stop:
channelGetConnect DBRdouble status Status [type=OK]
channelGetDone DBRdouble status Status [type=OK]
changed DBRdouble
= epics:nt/NTScalar:1.0
double value 0
alarm_t alarm
int severity 3
int status 2
string message UDF
time_t timeStamp
long secondsPastEpoch 631152000
int nanoseconds 0
int userTag 0
display_t display
double limitLow -10
double limitHigh 10
string description
string format
string units volts
control_t control
double limitLow -9
double limitHigh 9
double minStep 0
valueAlarm_t valueAlarm
boolean active false
double lowAlarmLimit -8
double lowWarningLimit -6
double highWarningLimit 6
double highAlarmLimit 8
int lowAlarmSeverity 0
int lowWarningSeverity 0
int highWarningSeverity 0
int highAlarmSeverity 0
double hysteresis 0
bitSet {0}
Type exit to stop:
changed DBRdouble
double value 0
alarm_t alarm
int severity 3
int status 2
string message UDF
time_t timeStamp
int nanoseconds 0
int userTag 0
display_t display
double limitLow -10
double limitHigh 10
string description
string format
string units volts
control_t control
double limitLow -9
double limitHigh 9
double minStep 0
double hysteresis 0
bitSet {0}
Type exit to stop:
But if I use ca I get
mrk> bin/linux-x86_64/get -p ca -r "value" DBRdouble
provider ca channelName PVRdouble request value debug false
_____get starting__
Type exit to stop:
CA.Client.Exception...............................................
Warning: "Identical process variable names on multiple servers"
Context: "Channel: "DBRdouble", Connecting to: 10.0.0.127:5064,
Ignored: localhost.localdomain:5064"
Source File: ../cac.cpp line 1320
Current Time: Tue Aug 14 2018 13:50:08.091716384
changed DBRdouble
= structure
double value 0
bitSet {0}
Type exit to stop:
channelGetDone DBRdouble status Status [type=OK] FOLLOWING IS
WRONG: BUG IN LATEST ca provider
changed DBRdouble
value = 0
bitSet {1}
Type exit to stop:
If I use database from release4_6, which uses pvaSrv
mrk> pwd
/home/epicsv4/release4_6/exampleCPP/database/iocBoot/exampleDatabase
Then I get:
mrk> pwd
mrk> bin/linux-x86_64/get -p pva -r "value" DBRdouble00
_____get starting__
Type exit to stop:
channelGetConnect DBRdouble00 status Status [type=OK]
channelGetDone DBRdouble00 status Status [type=OK]
changed DBRdouble00
double value 0
bitSet {0}
Type exit to stop:
Type exit to stop:
exit
mrk>
qsrv changed the rules.
I maintain that qsrv should follow the old rules.
Marty Kraimer
in the pvaGet I only request “value”.
The PV I am looking at is a classic V3 PV (ca) and on my server runs pvAccess-Server (qsrv).
ioc:
dbpr CRYAFM:AWG0:DDSA:SetDDSFreq,4
ACKS: NO_ALARM ACKT: YES ADEL: 0 ALST: 123456
AOFF: 0 ASG: ASLO: 0 ASP: 0x0
BKLNK: 00 00 00 00 00 00 00 00 00 00 00 00 BKPT: 00
DESC: Frequency DDS DDSA: DISA: 0 DISP: 0
DISS: NO_ALARM DISV: 1 DOL:CONSTANT DPVT: 0x19df880
DRVH: 0 DRVL: 0 DSET: 0x4fb724 DTYP: asynFloat64
EGU: Hz EGUF: 0 EGUL: 0 EOFF: 0
ESLO: 1 EVNT: FLNK:CONSTANT 0 HHSV: NO_ALARM
HIGH: 0 HIHI: 0 HOPR: 0 HSV: NO_ALARM
HYST: 0 INIT: 0 IVOA: Continue normally
IVOV: 0 LALM: 123456 LBRK: 0 LCNT: 0
LINR: NO CONVERSION LLSV: NO_ALARM LOLO: 0 LOPR: 0
LOW: 0 LSET: 0x1942808 LSV: NO_ALARM MDEL: 0
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 MLOK: 01 94 e7 40
MLST: 123456 NAME: CRYAFM:AWG0:DDSA:SetDDSFreq NSEV: NO_ALARM
NSTA: NO_ALARM OIF: Full OLDSIMM: NO OMOD: 0
OMSL: supervisory ORAW: 123456 ORBV: 0 OROC: 0
OUT:INST_IO @asyn(awg0, 0)DDS Frequency OVAL: 123456 PACT: 0
PBRK: 0x0 PHAS: 0 PINI: NO PPN: 0x0
PPNR: 0x0 PREC: 3 PRIO: LOW PROC: 0
PUTF: 0 PVAL: 123456 RBV: 0 RDES: 0xcdc5d0
ROFF: 0 RPRO: 0 RSET: 0x4fbac8 RVAL: 123456
SCAN: Passive SDIS:CONSTANT SDLY: -1 SEVR: NO_ALARM
SIML:CONSTANT SIMM: NO SIMPVT: 0x0 SIMS: NO_ALARM
SIOL:CONSTANT SPVT: 0x0 SSCN: <nil> STAT: NO_ALARM
TIME: 2018-08-14 08:51:37.697697041 TPRO: 0 TSE: 0
TSEL:CONSTANT UDF: 0 UDFS: INVALID VAL: 123456
humma-kavula:examples junkes$ cainfo CRYAFM:AWG0:DDSA:SetDDSFreq
State: connected
Host: cry-test.rz-berlin.mpg.de:5064
Access: read, write
Native data type: DBF_DOUBLE
Request type: DBR_DOUBLE
Element count: 1
humma-kavula:examples junkes$ pvinfo CRYAFM:AWG0:DDSA:SetDDSFreq
CHANNEL : CRYAFM:AWG0:DDSA:SetDDSFreq
STATE : CONNECTED
ADDRESS : 141.14.128.53:5075
double value
alarm_t alarm
int severity
int status
string message
time_t timeStamp
int nanoseconds
int userTag
display_t display
double limitLow
double limitHigh
string description
string format
string units
control_t control
double limitLow
double limitHigh
double minStep
boolean active
double hysteresis
get, nothing is changing ???
code fragment:
void get()
if(!channelConnected) {
cout << channelName << " channel not connected\n";
return;
if(!getConnected) {
cout << channelName << " channelGet not connected\n";
return;
pvaClientGet->get();
cout << "bitset Cardinality : " << bitSet->cardinality() << endl;
if(bitSet->cardinality()>0) {
cout << "changed " << channelName << endl;
data->showChanged(cout);
cout << "bitSet " << *bitSet << endl;
output:
channelGetConnect CRYAFM:AWG0:DDSA:SetDDSFreq status Status [type=OK]
channelGetDone CRYAFM:AWG0:DDSA:SetDDSFreq status Status [type=OK]
bitset Cardinality : 1
changed CRYAFM:AWG0:DDSA:SetDDSFreq
double value 123456
alarm_t alarm
int severity 0
int status 0
string message NO_ALARM
time_t timeStamp
long secondsPastEpoch 1534254697
int nanoseconds 697697041
int userTag 0
display_t display
double limitLow 0
double limitHigh 0
string description Frequency DDS DDSA:
string format
string units Hz
control_t control
double limitLow 0
double limitHigh 0
double minStep 0
double lowAlarmLimit nan
double lowWarningLimit nan
double highWarningLimit nan
double highAlarmLimit nan
double hysteresis 0
bitSet {0}
double value 123456
alarm_t alarm
int severity 0
int status 0
time_t timeStamp
int userTag 0
display_t display
double limitLow 0
double limitHigh 0
string format
string units Hz
control_t control
double limitLow 0
double limitHigh 0
double minStep 0
double hysteresis 0
bitSet {0}
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
- bitSets and PVStructure Heinz Junkes
Re: bitSets and PVStructure Michael Davidsaver
Re: EDM X/Y Plot segfaults Bruce Hill
<2018>
2025
2026
CS-Studio Archive engine data base connection error Vishnu Patel
<2018>
2025
2026
