Hi All,
I'm compiling areaDetector R3.3.2 on a Windows 10 machine. Macros (EPICS_BASE, ADCORE, ...) are defined at areaDetector level (e.g., EPICS_BASE in areaDetector-R3-3-2\configure\RELEASE_SUPPORT.local, ADCORE in areaDetector-R3-3-2\configure\RELEASE_LIBS.local) as instructed.
When compiling modules, it looks these definitions are removed as the compiler complains unable to find some files. For example, when compiling NDDriverStdArrays:
make -C ./src install
make[5]: Entering directory 'C:/EPICS/synApps-6-0/support/areaDetector-R3-3-2/NDDriverStdArrays/iocs/NDDriverStdArraysIOC/NDDriverStdArraysApp/src'
Makefile:27: /ADApp/commonDriverMakefile: No such file or directory
make[5]: *** No rule to make target '/ADApp/commonDriverMakefile'. Stop.
In areaDetector-R3-3-2\NDDriverStdArrays\iocs\NDDriverStdArraysIOC\NDDriverStdArraysApp\src\Makefile, the file was included as:
include $(ADCORE)/ADApp/commonDriverMakefile
I change $(ADCORE) to the full path to ADCore, and the error disappeared. But new errors appeared:
make[6]: Entering directory 'C:/EPICS/synApps-6-0/support/areaDetector-R3-3-2/NDDriverStdArrays/iocs/NDDriverStdArraysIOC/NDDriverStdArraysApp/src/O.windows-x64-static'
Creating dbd file NDDriverStdArraysApp.dbd
perl -CSD C:/EPICS/base-7.0.1.1/bin/windows-x64-static/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -IC:/EPICS/base-7.0.1.1/dbd -o NDDriverStdArraysApp.dbd NDDriverStdArraysSupport.dbd
perl -CSD C:/EPICS/base-7.0.1.1/bin/windows-x64-static/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -IC:/EPICS/base-7.0.1.1/dbd -o NDDriverStdArraysApp_registerRecordDeviceDriver.cpp ../O.Common/NDDriverStdArraysApp.dbd NDDriverStdArraysApp_registerRecordDeviceDriver C:/EPICS/synApps-6-0/support/areaDetector-R3-3-2/NDDriverStdArrays/iocs/NDDriverStdArraysIOC
perl -CSD C:/EPICS/base-7.0.1.1/bin/windows-x64-static/mkmf.pl -m NDDriverStdArraysApp_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I../../../../../include -IC:/EPICS/base-7.0.1.1/include/compiler/msvc -IC:/EPICS/base-7.0.1.1/include/os/WIN32 -IC:/EPICS/base-7.0.1.1/include NDDriverStdArraysApp_registerRecordDeviceDriver.obj NDDriverStdArraysApp_registerRecordDeviceDriver.cpp
Installing created dbd file ../../../dbd/NDDriverStdArraysApp.dbd
cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -Oy- -W3 -w44355 -w44344 -w44251 -MT -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I../../../../../include -IC:/EPICS/base-7.0.1.1/include/compiler/msvc -IC:/EPICS/base-7.0.1.1/include/os/WIN32 -IC:/EPICS/base-7.0.1.1/include -c NDDriverStdArraysApp_registerRecordDeviceDriver.cpp
link -nologo -incremental:no -opt:ref -release -MACHINE:X64 -out:NDDriverStdArraysApp.exe NDDriverStdArraysApp_registerRecordDeviceDriver.obj NDDriverStdArraysAppMain.obj ../../../../../lib/windows-x64-static/NDDriverStdArrays.lib ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
NDDriverStdArraysApp_registerRecordDeviceDriver.obj : error LNK2019: unresolved external symbol iocshRegister referenced in function "int __cdecl Registration(void)" (?Registration@@YAHXZ)
NDDriverStdArrays.lib(NDDriverStdArrays.obj) : error LNK2001: unresolved external symbol iocshRegister
NDDriverStdArraysApp_registerRecordDeviceDriver.obj : error LNK2019: unresolved external symbol iocshRegisterCommon referenced in function "int __cdecl Registration(void)" (?Registration@@YAHXZ)
NDDriverStdArraysApp_registerRecordDeviceDriver.obj : error LNK2019: unresolved external symbol iocshPpdbbase referenced in function rrddCallFunc
I removed NDDriverStdArrays from the compiling list in the areaDetector-R3-3-2\configure\RELEASE.local and then same errors occurred when compiling another module (pvaDriver).
I don't think it the right way to find all the definitions that cause such errors and change them manually. Did I missed some configurations?
Thanks.
-Ji Li
- RE: Macro definitions for compiling areaDetector R3.3.2 Mark Rivers
Re: Virtual circuit unresponsive on CA Gateway Hu, Yong
<2018>
2025
2026
Re: Virtual circuit unresponsive on CA Gateway 윤상원
<2018>
2025
2026
