1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Newport XPS-D8
To: 'John Dobbins' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Aug 2018 19:16:33 +0000
Hi John,
We just received our first XPS-D8 models last week.  The advertised claim that they are completely hardware and software compatible with the XPS-Q8 is not true.  These are the differences we have found so far:
-          The D8 does not support FTP to fetch/load configuration files or trajectory definition files.  It supports SFTP.  This means that the trajectory/profile move code in the driver will need to be changed.
-          The I/O connector that has the pulse outputs for trajectory scans has changed.  The C8 and Q8 have a DB-25 connector.  The D8 has a DB-50 connector and different pins.
The basic motor record support appears to work OK in our initial testing.
From: [email protected] <[email protected]> On Behalf Of John Dobbins
Sent: Wednesday, August 29, 2018 2:11 PM
To: [email protected]
Subject: Newport XPS-D8
Is the motor record known to work with the latest version of the Newport XPS hardware, XPS-D8?
John Dobbins
Research Support Specialist
Cornell Laboratory for Accelerator Sciences and Education
Cornell University
Newport XPS-D8 John Dobbins
Prev: Newport XPS-D8 John Dobbins
Next: Re: Newport XPS-D8 Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
