1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Archiver Appliance: Adding a PV with an Alias
Cc: DPCuneo <[email protected]>
Date: Thu, 30 Aug 2018 17:43:22 +0000
There is support for EPICS aliases. The NAME/NAME$ fields of the PV are used to lookup the "real" name and the PV is archived under that name and an entry is added to the PVAliases table with the alias name. Data retrieval and management are supported under both names.
For aliased PV's, the PVDetails of the PV should an a line indicating that this PV is an alias for the "real" PV.
To debug this, I'd do a caget <PV>.NAME (or NAME$ if it is a long name) and then see if the PV is archived under that name. Also, in the mgmt arch.log, you should seen an entry that looks like
Aborting archive request for pv XRT:LIPY:0:HXX:HXM:MMS_01:B_MPSC:LIGHT_TRANS Reason: Aborting this pv XRT:LIPY:0:HXX:HXM:MMS_01:B_MPSC:LIGHT_TRANS (which is an alias) and using the real name XRT:LIPY:0:HXX:HXM:MMS_01:B_MPSC:LIGHT_ instead.
Murali
Prev: Archiver Appliance: Adding a PV with an Alias Daniel Cuneo
Next: IOC for Spark Autosampler Alias Gabriel de Souza Fedel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
