Hello everybody,
On July I've asked here if anyone had a device suppport for N-Helix, and I got many responses of already implemented support. At this time, I'm trying to establish communication with N-Helix using AsynDriver, through
ethernet interface. We've run some tests here, and N-Helix wasn't able to get a dynamic IP address from the DHCP server. I've tried to set the IP statically and I've used a crossover cable, but it didn't work too. I've suspected that N-Helix was rejecting
any incoming connection, and I've used 'nmap' command to map its ports, which seem to be all blocked (filtered, it says). So, am I right to think that N-Helix is not configured to accept any communication, either by TCP or UDP protocols?
Any help and work around is welcome.
Thank you ,
Allan S. B. Bugyi
Technology Development Analyst
[email protected]
(+55 19) 3512-3520
SOL/Beamline Software Group
Brazilian Synchrotron Light
Laboratory (LNLS)
Center of Research in Energy and Materials (CNPEM)
http://lnls.cnpem.br
xygraph annotation setting Amien Crombie
Re: Asyn: disconnect and reconnect port via PV Bruno Martins
<2018>
2025
2026
New EPICS Website: epics-controls.org Andrew Johnson
<2018>
2025
2026
ANJ, 31 Aug 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
