1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn: disconnect and reconnect port via PV
To: "'Niedermayer, Philipp'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 31 Aug 2018 13:27:08 +0000
Hi Philip,
You should be able to do what you want by loading an asynRecord in that IOC and setting its PORT field to the name of “device_port” you used in the vxi11Configure command.  Below is a screen shot of the medm screen for controlling the asynRecord.  Note that there are 2 widgets labelled “Connect”, which is a bit confusing.
The upper one is the .PCNCT field and connects the asynRecord to an asyn port.  It results in a call to pasynManager->connectDevice() or pasynManager->disconnect().  You want to leave that in the Connect state.
The lower one is the .CNCT field, and connects or disconnects the actual device, i.e. it calls pasynCommon->connect() or pasynCommon->disconnect().  If you select Disconnect on this then it will close the VXI11 connection.  You will also need to set the .AUCT field to noAutoConnect so that asynManager does not try to automatically reconnect the device the next time a record tries to communicate with it.
Let me know if you have questions or problems.
From: [email protected] <[email protected]> On Behalf Of Niedermayer, Philipp
Sent: Friday, August 31, 2018 1:28 AM
To: [email protected]
Subject: Asyn: disconnect and reconnect port via PV
Hello everyone,
I have implemented a soft IOC that communicates to a spectrum analyzer via asyn and stream device using vxi11:
vxi11Configure("device_port","$(DEVICE_IP)",0,"0.0","inst0",0,0)
The device has a limitation that it can only be controlled by one remote controller at a time. The current approach is to temporarily stop the entire soft IOC when required and then restart it via the st.cmd file.
It would be better to have a PV (e.g. a bo with CONNECTED/DISCONNECTED state) for this task, that can dis- and reconnect the asyn port.
I know that you can disable record processing by the DISA field, but that did not prevent asyn to keep up a connection to the device in background.
I found the “asynManager” which has the promising “connectDevice” and “disconnect” option, but I’m not sure how to (if at all) call them from the PV.
Is there a way to have such a PV? How could that be implemented?
Greetings and tanks in advance
Philipp
Forschungszentrum Juelich GmbH
52425 Juelich
Sitz der Gesellschaft: Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Prof. Dr. Sebastian M. Schmidt
AW: Asyn: disconnect and reconnect port via PV Niedermayer, Philipp
Prev: Re: Asyn: disconnect and reconnect port via PV Bruno Martins
Next: New EPICS Website: epics-controls.org Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: AW: Asyn: disconnect and reconnect port via PV Niedermayer, Philipp
ANJ, 04 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
