1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Linux scan thread suspended
To: 'Pilar Gil Jaldo' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 5 Sep 2018 23:01:58 +0000
Hi Pilar,
I am confused.  You said:
Ø  It is a 64 bit machine running EPICS 3.13.7  with..
What OS is the IOC running?  If it is running base 3.13.7 then it must be vxWorks, because OS-independent IOC core only started with 3.14.  Is it really a 64-bit vxWorks machine, or did you make a typo on the version of base?
Sent: Wednesday, September 5, 2018 9:22 AM
To: Mark Rivers <[email protected]>; [email protected]
Subject: Re: Linux scan thread suspended
Hello Mark,
Thank you for your reply. I'm going to give a little bit more information about the system.
             total       used       free     shared    buffers     cached
Mem:          7812        700       7112          0         49        410
I was speculating with a network problem because I have the same system with the same configuration running outside the network and I have never seen this error before. This error is just happing since the other devices are requesting messages to the CA Network without getting an answer from the offline devices.
The possibility of a non zero terminated string would be also strange because in the other running system everything is working fine.
Thank you very much in advance!
Pilar
On 05/09/18 16:02, Mark Rivers wrote:
Hi Pilar,
I think your case is different from the tech-talk thread.  In the tech-talk thread they said there was no IOC error mesage, but in  your case you have a very clear IOC error message:
epicsStrDup: mallocMustSucceed(1) - malloc failed Thread scan2 (0x9c2b038) suspending.
This says to me that your IOC has run out of memory.  I suspect there is a memory leak somewhere.
Is this a 32 or 64 bit machine, and how much memory does it have?
You could restart the IOC and use "top" to look at the memory usage with time.
What version of EPICS are you using, and what devices does this IOC control?
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Pilar Gil Jaldo
Sent: Wednesday, September 5, 2018 8:36 AM
To: [email protected]
Subject: Linux scan thread suspended
Hello everybody,
I have a question regarding the reasons why a scan thread can be suspended. I have a running IOC and at a certain moment the IOC breaks with following message:
I have found in the tech-talk messages following reason which seems to be the same problem that mine.
https://epics.anl.gov/tech-talk/2013/msg00154.php
The IOC is on a network where many devices are sending packages to the CA network, but nobody is answering because other devices are switched off (the traffic in the CA is very high).
Is it possible that the segmentation fault is caused by a network congestion? Can the scan thread be suspended by a higher network traffic?
Thank you very much in advance for your answers.
Pilar Gil Jaldo
http://sevensols.com
Pilar Gil Jaldo
Embedded SW Engineer
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it.
Re: Linux scan thread suspended Pilar Gil Jaldo
RE: Linux scan thread suspended Mark Rivers
Prev: Re: Problem with database parsing in EPICS 7.0.1 Ralph Lange
Next: RE: Linux network tuning Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Linux scan thread suspended Pilar Gil Jaldo
Next: Re: Linux scan thread suspended Pilar Gil Jaldo
ANJ, 06 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
