1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asking for help on s7nodave
From: "=?gb18030?b?s8nN/rvG5a0=?=" <[email protected]>
To: "=?gb18030?b?TWFyayBSaXZlcnM=?=" <[email protected]>, "=?gb18030?b?dGVjaC10YWxr?=" <[email protected]>
Date: Fri, 7 Sep 2018 15:45:45 +0800
Hi, Mark,
My mail box just put this email to trash...
I folllow what you said and the result is
what I did:
in exampleApp/src/Makefile, modify
ifneq ($(SNCSEQ),)
    # Build sncExample into exampleSupport
    sncExample_SNCFLAGS += +r
    example_DBD += sncExample.dbd
    # A .stt sequence program is *not* pre-processed:
    exampleSupport_SRCS += sncExample.stt
    exampleSupport_LIBS += seq pv
    example_LIBS += seq pv
    # Build sncProgram as a standalone program
    PROD_HOST += sncProgram
    sncProgram_SNCFLAGS += +m
    # A .st sequence program *is* pre-processed:
    sncProgram_SRCS += sncProgram.st
    sncProgram_LIBS += seq pv
    sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
#by hy
example_DBD += s7nodave.dbd
example_LIB += s7nodave
example_DBD += asyn.dbd
example_DBD += asynRecord.dbd
example_DBD += drvAsynIPPort.dbd
# Finally link IOC to the EPICS Base libraries
example_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD EXTRA GNUMAKE RULES BELOW HERE
example_LIBS += asyn
than I make, it failed.
root@hy-VirtualBox:~/epics/mytest/exampleApp/src# make
/root/epics/base/configure/RULES_ARCHS:57: target 'inc.linux-x86_64' given more than once in the same rule
/root/epics/base/configure/RULES_ARCHS:57: target 'build.linux-x86_64' given more than once in the same rule
/root/epics/base/configure/RULES_ARCHS:57: target 'install.linux-x86_64' given more than once in the same rule
/root/epics/base/configure/RULES_ARCHS:57: target 'buildInstall.linux-x86_64' given more than once in the same rule
/root/epics/base/configure/RULES_ARCHS:57: target 'runtests.linux-x86_64' given more than once in the same rule
/root/epics/base/configure/RULES_ARCHS:57: target 'tapfiles.linux-x86_64' given more than once in the same rule
/root/epics/base/configure/RULES_ARCHS:61: target 'linux-x86_64' given more than once in the same rule
/root/epics/base/configure/RULES_ARCHS:66: target 'O.linux-x86_64' given more than once in the same rule
/root/epics/base/configure/RULES_ARCHS:82: target 'clean.linux-x86_64' given more than once in the same rule
make: Circular install.linux-x86_64 <- install.linux-x86_64 dependency dropped.
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory '/root/epics/mytest/exampleApp/src/O.linux-x86_64'
Creating dbd file example.dbd
perl -CSD /root/epics/base/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/root/epics/seq/dbd -I/root/epics/base/dbd -I/root/epics/asyn4-33/dbd -I/root/epics/s7nodave/dbd -o example.dbd base.dbd xxxSupport.dbd dbSubExample.dbd exampleHello.dbd initTrace.dbd sncExample.dbd s7nodave.dbd asyn.dbd asynRecord.dbd drvAsynIPPort.dbd
dbdExpand.pl: Duplicate definition of record type ''
Context: recordtype(asyn) in file '/root/epics/asyn4-33/dbd/asynRecord.dbd'
  while reading 'asynRecord.dbd' to create 'example.dbd'
dbdExpand.pl: Exiting due to errors
make[1]: *** No rule to make target '../O.Common/example.dbd', needed by 'build'.  Stop.
make[1]: Leaving directory '/root/epics/mytest/exampleApp/src/O.linux-x86_64'
/root/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make: *** [install.linux-x86_64] Error 2
黄 瀛
*****开票信息*****
名称:绵阳成威实验室工程技术有限公司
税号:915107 0455 1000 912T
注册地址:四川省绵阳市游仙区仙人路一段32号
开户银行:中国银行绵阳游仙支行
账号:1279 5046 6834
*****送货信息*****
地址:四川省绵阳市游仙区游仙镇仙童街一号,电商谷
联系人:黄瀛
电话:18784065819
Ying Huang
Chengwei Lab&Engineering Company
No1 Xiantong Street, Youxian Area, Mianyang City, Sichuan Province, China
86 0816 2967213
------------------ Original ------------------
Date:  Thu, Sep 6, 2018 08:16 PM
To:  "成威黄瀛"<[email protected]>;"tech-talk"<[email protected]>;
I think your problems are these 2 lines:
my_DBD += s7nodave.dbd
my_LIB += s7nodave
Since your application is called "example" those should be
You also need to make sure that exampleApp/src/Makefile contains
It may also need
The above lines should be earlier in the Makefile, before this line:
From: [email protected] <[email protected]> on behalf of 成威黄瀛 <[email protected]>
Sent: Thursday, September 6, 2018 3:56 AM
To: tech-talk
Subject: asking for help on s7nodave
Currently I am trying to make connection with epics and PLC, using s7nodave. I am following this guideline http://oss.aquenos.com/epics/s7nodave/docs/2.1.3/manual.html#recordreference
Below is what I have done but I am stuck.
1, Install EPICS base. Version is 3.15.5
root@hy-VirtualBox:~/epics/base# ls
bin        db   documentation  include  LICENSE   README  startup
configure  dbd  html           lib      Makefile  src     templates
2, "makeBaseApp.pl -t example example"    " makeBaseApp.pl -i -t example example"      to build up mytest, the IOC application.
root@hy-VirtualBox:~/epics/mytest# ls
bin  configure  db  dbd  exampleApp  include  iocBoot  lib  Makefile
3, install asynDriver. Version is 4-33
Following this link, I add BPICS_BASE=/root/epics/base to asyn4-33/configure/RELEASE
https://epics.anl.gov/modules/soft/asyn/
root@hy-VirtualBox:~/epics/asyn4-33# ls
asyn           iocBoot      testApp                 testGpibApp
bin            lib          testArrayRingBufferApp  testGpibSerialApp
configure      LICENSE      testAsynPortClientApp   testIPServerApp
db             Makefile     testAsynPortDriverApp   testManagerApp
dbd            makeSupport  testBroadcastApp        testOutputCallbackApp
documentation  opi          testConnectApp          testOutputReadbackApp
html           README.md    testEpicsApp            testUsbtmcApp
include        templates    testErrorsApp
4,put boost_1_67_0 in a certain folder but not compile
root@hy-VirtualBox:~/epics/boost_1_67_0# ls
boost            boost.png      index.htm   libs             status
boost-build.jam  bootstrap.bat  index.html  LICENSE_1_0.txt  tools
boostcpp.jam     bootstrap.sh   INSTALL     more
boost.css        doc            Jamroot     rst.css
5, in s7nodave, configure/RELEASE file, add EPICS_BASE, ASYN, RELEASE_INCLUDES, and make s7nodabe
# If using the sequencer, point SNCSEQ at its top directory:
#SNCSEQ=$(EPICS_BASE)/../modules/soft/seq
SNCSEQ=/root/epics/seq
# The ASYN variable has to point to the asyn director.
#ASYN=/opt/epics/modules/synApps_5_5/support/asyn-4-13
ASYN=/root/epics/asyn4-33
# If the headers of the Boost library (http://www.boost.org/) are not installed
# in one of the default header locations (usually /usr/include and
# /usr/local/include) the includes path has to be added to RELEASE_INCLUDES.
# Only Boost headers are used, there is no need to compile the Boost library.
#RELEASE_INCLUDES+=-I/my/path/to/boost_1_47_0
RELEASE_INCLUDES+=-I/root/epics/boost_1_67_0
# EPICS_BASE usually appears last so other apps can override stuff:
#EPICS_BASE=/opt/epics/base-3.14.12
EPICS_BASE=/root/epics/base
# Set RULES here if you want to take build rules from somewhere
# other than EPICS_BASE:
#RULES=/path/to/epics/support/module/rules/x-y
# Allow the user to override settings locally.
-include $(TOP)/configure/RELEASE.local
6, in configure/RELEASE file of my own project, add "S/NODAVE=/opt/epics/modules/s7nodave"
# EPICS_BASE should appear last so earlier modules can override stuff:
# Set RULES here if you want to use build rules from somewhere
#RULES = $(MODULES)/build-rules
# These allow developers to override the RELEASE variable settings
# without having to modify the configure/RELEASE file itself.
-include $(TOP)/../RELEASE.local
S/NODAVE=/root/epics/s7nodave
S7NODAVE=/root/epics/s7nodave
7, add "my_DBD += s7nodave.dbd"   "my_LIBS += s7nodave"  to /root/epics/mytest/exampleApp/src/Makefile
#by hy
my_LIB += s7nodave
After these configure, I run st.cmd, however, IOC shell still cannot recoginze the command s7nodaveConfigureIsoTcpPort
I notice the guideline mentioned that "However, you have to add asyn.dbd to the list of DBDs used by your project in order to enable these commands in the IOC shell. "
But how can I add asyn.dbd to IOC shell???? by dbLoadDatabase "/root/epics/asyn4-33/dbd/asyn.dbd" ????????????????
< envPaths
epicsEnvSet("IOC","iocexample")
epicsEnvSet("TOP","/root/epics/mytest")
epicsEnvSet("EPICS_BASE","/root/epics/base")
epicsEnvSet("ASYN","/root/epics/asyn4-33")
epicsEnvSet("S7NODAVE","/root/epics/s7nodave")
epicsEnvSet("SNCSEQ","/root/epics/seq")
cd "/root/epics/mytest"
dbLoadDatabase "dbd/example.dbd"
## dbLoadDatabase "/root/epics/asyn4-33/dbd/asyn.dbd"
## dbLoadDatabase "/root/epics/asyn4-33/dbd/asynRecord.dbd"
## dbLoadDatabase "/root/epics/asyn4-33/dbd/devEpivd.dbd"
example_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/user.substitutions"
dbLoadRecords "db/dbSubExample.db", "user=root"
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
#traceIocInit
cd "/root/epics/mytest/iocBoot/iocexample"
iocInit
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Sep  2 2018
## Start any sequence programs
#seq sncExample, "user=root"
epics> s7nodaveConfigureIsoTcpPort
Command s7nodaveConfigureIsoTcpPort not found.
epics>
黄 瀛
*****?票信息*****
名称:??成威??室工程技?有限公司
注册地址:四川省??市游仙区仙人路一段32号
???行:中国?行??游仙支行
?号:1279 5046 6834
*****送?信息*****
地址:四川省??市游仙区游仙?仙童街一号,?商谷
?系人:黄瀛
??:18784065819
Ying Huang
86 0816 2967213
RE: asking for help on s7nodave Mark Rivers
asking for help on s7nodave =?gb18030?b?s8nN/rvG5a0=?=
Re: asking for help on s7nodave Mark Rivers
Prev: Problems with soft motors Mark Rivers
Next: Re: asking for help on s7nodave =?gb18030?b?s8nN/rvG5a0=?=
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asking for help on s7nodave Mark Rivers
Next: RE: asking for help on s7nodave Mark Rivers
ANJ, 07 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
