1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with soft motors
To: "Rivers, Mark L." <[email protected]>, "Peterson, Kevin M." <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Sat, 8 Sep 2018 03:30:00 +0000
Hi Mark,
Awesome.  I don't have the understanding of the differences between 3.15 and EPICS 7 to guess how they are actually playing underneath.  It seems to me this code should not only be modified, but rethought.  I think we should think of it as an initial stab at a soft motor, for the purpose of enabling the study of problems in writing databases involving several soft motors, and it served pretty well for that purpose.  But I have never thought DINP should be handled in this way.  Unfortunately, I can't now remember why I thought that, and I can't study it now because I'm on travel next week and have to prepare.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Friday, September 7, 2018 6:20:14 PM
To: Mooney, Tim M.; Peterson, Kevin M.; Johnson, Andrew N.
Cc: '[email protected]'
Subject: RE: Problems with soft motors
I’ve figured out why it is not adding the dinp link for some motors.
This is the current code with my previous fix:
        if (mr->dinp.value.constantStr == NULL)
            ptr->default_done_behavior = true;
        else if (mr->dinp.value.pv_link.pvname != NULL)
            ptr->default_done_behavior = false;
printf("devSoftAux::soft_motor_task: adding dinp link for motor %s link=%s\n", mr->name, mr->dinp.value.pv_link.pvname);
            SEVCHK(ca_search(mr->dinp.value.pv_link.pvname, &dinp),
                   "ca_search() failure");
The problem is that for motors pm2, pm4, pm6 mr->dinp.value.constantStr is NULL, so it does not call the ca_search.
I don’t understand link structures well enough to understand why for some records mr->dinp.value.constantStr is NULL, while for others it is not.  For all motors mr->dinp.value.pv_link.pvname contains the correct value.
I can fix the problems completely by changing the code to the following:
        if (mr->dinp.value.pv_link.pvname == NULL)
        else
So I am replacing the test mr->dinp.value.constantStr==NULL with the test mr->dinp.value.pv_link.pvname==NULL.  But I don’t know if this is the desired behavior when the DINP field is not defined.
Sent: Friday, September 7, 2018 5:32 PM
To: 'Mooney, Tim M.' <[email protected]>; Peterson, Kevin M. <[email protected]>; Johnson, Andrew N. <[email protected]>
Cc: [email protected]
Hi Tim,
Ø  Do you see the error message "cannot find dbCaLink task." in the IOC console output after iocInit?
No, but there are definitely problems in devSoftAux.cc.
I have found that there were 2 problems.
1)      devSoftAux::soft_motor_task has calls to the CA library like this:
This means that if there is a CA error then it kills the task and no other needed CA callbacks get established.  In one of my IOCs where no soft motor callbacks were happening at all, this was the issue.  The soft_motor_task did not exist, whereas it did exist in all the other IOCs.  I tracked the problem down to one soft motor in the system that does not have string defined for the DINP link.  In previous versions of base this worked OK.  However, in base 7 it caused the task to exit with the following error:
CA.Client.Exception...............................................
    Error: "Invalid string"
    Context: "ca_search() failure"
    Source File: ../devSoftAux.cc line 172
    Current Time: TUE SEP 04 2018 13:39:36.049462058
This is the code that did it:
        else
The problem is that since when the link is not defined dinp.value.pv_link.pvname is NULL, and ca_search returns an error.  I don’t know why this worked in 3.14 and 3.15, but it did.  I was able to fix this problem by not calling the CA functions if dinp.value.pv_link.pvname  is NULL.
I also temporarily added the debugging printf for each type of link that gets callbacks established in this function.  That let me see what the second problem is.
2)      The second problem is exposed with the printf statements added when the callbacks are established.  This is what I see during iocInit:
devSoftAux::soft_motor_task: adding dinp link for motor 13BMA:pm1 link=13BMA:KBVB:Done
devSoftAux::soft_motor_task: adding urip link for motor 13BMA:pm1 link=13BMA:KBVB:Readback.G
devSoftAux::soft_motor_task: adding urip link for motor 13BMA:pm2 link=13BMA:KBVB:Readback.H
devSoftAux::soft_motor_task: adding dinp link for motor 13BMA:pm3 link=13BMA:KBVP:Done
devSoftAux::soft_motor_task: adding urip link for motor 13BMA:pm3 link=13BMA:KBVP:Readback.G
devSoftAux::soft_motor_task: adding urip link for motor 13BMA:pm4 link=13BMA:KBVP:Readback.H
devSoftAux::soft_motor_task: adding dinp link for motor 13BMA:pm5 link=13BMA:KBVT:Done
devSoftAux::soft_motor_task: adding urip link for motor 13BMA:pm5 link=13BMA:KBVT:Readback.G
devSoftAux::soft_motor_task: adding urip link for motor 13BMA:pm6 link=13BMA:KBVT:Readback.H
The above output shows the problem.  For each soft motor it should be adding callbacks for both the dinp (done moving) and urip (position) links.  It is correctly adding the urip link for each motor.  However, it is only adding the dinp links for every other motor (pm1, pm3, pm5).  It is not adding the dinp link for (pm2,pm4,pm6).
I don’t understand this, since pm1 and pm2 seem to be defined identically for their DINP links.
ioc13bma> dbpr "13BMA:pm1",2
ACCL: 0.1           ACKS: NO_ALARM      ACKT: YES           ADEL: 0
ASG:                ATHM: 0             BACC: 0.1           BDST: 0
BKPT: 00            BVEL: 1             CDIR: 0             CNEN: Disable
DCOF: 0             DESC: Curvature     DHLM: 10000         DIFF: 0
DINP:DB_LINK 13BMA:KBVB:Done NPP NMS    DIR: Pos            DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DLLM: -10000
DLY: 0              DMOV: 1             DOL:CONSTANT        DRBV: 0.25
DTYP: Soft Channel  DVAL: 0.25          EGU: mm             ERES: 1.0e-04
EVNT:               FLNK:CONSTANT       FOF: 0              FOFF: Frozen
FRAC: 1             HHSV: NO_ALARM      HIGH: 0             HIHI: 0
HLM: 10000          HLS: 0              HLSV: NO_ALARM      HOMF: 0
HOMR: 0             HOPR: 0             HSV: NO_ALARM       HVEL: 0.1
ICOF: 0             IGSET: 0            INIT:               JAR: 10
JOGF: 0             JOGR: 0             JVEL: 1             LCNT: 0
LDVL: 0.25          LLM: -10000         LLS: 0              LLSV: NO_ALARM
LOCK: NO            LOLO: 0             LOPR: 0             LOW: 0
LRLV: 0             LRVL: 2500          LSPG: Go            LSV: NO_ALARM
LVAL: 0.25          LVIO: 0             MDEL: 0             MISS: 0
MOVN: 0             MRES: 1.0e-04       NAME: 13BMA:pm1     NSEV: NO_ALARM
NSTA: NO_ALARM      NTM: NO             NTMF: 2             OFF: 0
OMSL: supervisory   OUT:DB_LINK 13BMA:pm1DVAL.VAL PP MS     PACT: 0
PCOF: 0             PHAS: 0             PINI: NO            POST:
PP: 0               PREC: 3             PREM:               PRIO: LOW
PUTF: 0             RBV: 0.25           RCNT: 0             RDBD: 1.0e-04
RDBL:DB_LINK 13BMA:KBVB:Readback.G NPP NMS                  RDIF: 0
REP: 0              RHLS: 0             RINP:CONSTANT       RLLS: 0
RLNK:CONSTANT       RLV: 0              RMOD: Default       RMP: 2500
RPRO: 0             RRBV: 2500          RRES: 1             RTRY: 0
RVAL: 2500          RVEL: 0             S: 50               SBAK: 50
SBAS: 5             SCAN: Passive       SDIS:CONSTANT       SET: Use
SEVR: NO_ALARM      SMAX: 50            SPMG: Go            SREV: 200
SSET: 0             STAT: NO_ALARM      STOO:DB_LINK 13BMA:KBVB:Stop PP MS
STOP: 0             SUSE: 0             SYNC: 0             TDIR: 0
TIME: 2018-09-07 17:04:51.807438608     TPRO: 0             TSE: 0
TSEL:CONSTANT       TWF: 0              TWR: 0              TWV: 0.2
UDF: 0              UDFS: INVALID       UEIP: No            UREV: 0.02
URIP: Yes           VAL: 0.25           VBAS: 0.1           VELO: 1
VERS: 6.1           VMAX: 1             VOF: 0
value = 0 = 0x0
ioc13bma> dbpr "13BMA:pm2",2
DCOF: 0             DESC: Ellipticity   DHLM: 10000         DIFF: 0
DLY: 0              DMOV: 1             DOL:CONSTANT        DRBV: -0.0999
DTYP: Soft Channel  DVAL: -0.0999       EGU: mm             ERES: 1.0e-04
LDVL: -0.0999       LLM: -10000         LLS: 0              LLSV: NO_ALARM
LRLV: 0             LRVL: -999          LSPG: Go            LSV: NO_ALARM
LVAL: -0.0999       LVIO: 0             MDEL: 0             MISS: 0
MOVN: 0             MRES: 1.0e-04       NAME: 13BMA:pm2     NSEV: NO_ALARM
OMSL: supervisory   OUT:DB_LINK 13BMA:pm2DVAL.VAL PP MS     PACT: 0
PUTF: 0             RBV: -0.0999        RCNT: 0             RDBD: 1.0e-04
RDBL:DB_LINK 13BMA:KBVB:Readback.H NPP NMS                  RDIF: 0
RLNK:CONSTANT       RLV: 0              RMOD: Default       RMP: -999
RPRO: 0             RRBV: -999          RRES: 1             RTRY: 0
RVAL: -999          RVEL: 0             S: 50               SBAK: 50
TSEL:CONSTANT       TWF: 0              TWR: 0              TWV: 0.1
URIP: Yes           VAL: -0.0999        VBAS: 0.1           VELO: 1
value = 0 = 0x0
So one problem is fixed, and I know what the other problem is, but not yet how to fix it.
Sent: Friday, September 7, 2018 12:15 PM
To: Mark Rivers <[email protected]>; Peterson, Kevin M. <[email protected]>; Johnson, Andrew N. <[email protected]>
Hi Mark,
I'll make a wild guess:  The function, soft_init(), in motor/motorApp/SoftMotorSrc/devSoftAux.cc, seems vulnerable to changes in EPICS base that might not have had consequences for other code I know of.  This code has always seemed a little hinky to me.  Do you see the error message "cannot find dbCaLink task." in the IOC console output after iocInit?
Sent: Thursday, September 6, 2018 6:23:32 PM
To: Peterson, Kevin M.; Mooney, Tim M.; Johnson, Andrew N.
Subject: Problems with soft motors
I am having a serious problem with soft motor device support.  These are databases that have worked fine for over 10 years.  The databases are the ones in motorApp/Db: pseudoMotor.db and sumDiff2D.db.
The databases are very simple: there are 2 real motors and 2 soft motors.  One soft motor moves both real motors in the same direction, and the other soft motor moves the real motors in the opposite direction.  The readback of the first soft motor is the average of the real motors, while the other is the difference of the real motors.  The calculations are done in transform records.  There is also a transform record that calculates when the soft motors are done moving, which is just the logical AND of the real motor .DMOV fields.
The main problem I am seeing is that the transform records are updating OK, but for some motors these values are not getting back into the motor record.
Here is an example of the debugging output of the devSoft.cc when a real motor is moved, and the soft motors, pm5 and pm6 are updating during that real motor move.
soft_dinp_func(): HARDMOVE set for 13BMD:pm5.
soft_rdbl_func(): updated RMP = 901 for 13BMD:pm5.
update(): dmov=0 for 13BMD:pm5.
update(): DMOV=0 for 13BMD:pm5.
soft_rdbl_func(): updated RMP = 23 for 13BMD:pm6.
update(): dmov=1 for 13BMD:pm6.
update(): DMOV=1 for 13BMD:pm6.
soft_rdbl_func(): updated RMP = 930 for 13BMD:pm5.
soft_rdbl_func(): updated RMP = 80 for 13BMD:pm6.
soft_dinp_func(): Done moving set for 13BMD:pm5.
update(): DMOV=1 for 13BMD:pm5.
soft_rdbl_func(): updated RMP = 940 for 13BMD:pm5.
update(): dmov=1 for 13BMD:pm5.
soft_rdbl_func(): updated RMP = 101 for 13BMD:pm6.
In this case pm5 is working fine.  It detected that dmov initially went to 0, and so at the end of the move it set the VAL field to match the RBV field.
However, pm6 is not working correctly.  It is detecting the readback changes, but it does not get the correct value of dmov.  It always sees it as 1, not as 0 which it should.  This means that at the end of the move it does not set the VAL field to match RBV.  pm5 and pm6 are configured identically, and they both get their DMOV value from the same field of the same transform record.  Why does one work and one not work?
Here are some symptoms of the problem:
- Some soft motors work fine, and others do not, even when they are apparently configured identically.  For one set of soft motors in one of my IOCs there are no updates printed with debugging in devSoft.cc.  For these soft motors neither the RBV fields nor the VAL fields update at all when the real motors are moved.
- The behavior of a particular motor is always the same, through multiple reboots, i.e. it either works or does not work.
- This has all worked fine until this shutdown when I made a lot of changes:
    Base 3.15.5 > 7.0.1.1
    synApps modules (motor, calc, etc.): master January 2018 to master August 2018.
- The devSoft.cc has not changed since 2015 so that cannot be the problem.
- I tried reverting the motorRecord.cc to the commit from Jan. 4, 2018 which is what I was using in the last run when it worked fine.  That did NOT fix the problem, which was very surprising.  This suggests that perhaps the problem has something to do with links in the transform record, or some change in base?
- I reverted the entire IOC application to the version I was running in the last run (3.15.5, master branch of synApps from January 2018) and all of the soft motors work fine.  This seems to prove it is some software change in base 7.0.1 vs 3.15.5, or a change in synApps since January.  But it is NOT the motor record itself.
Help!
Problems with soft motors Mark Rivers
Re: Problems with soft motors Mooney, Tim M.
RE: Problems with soft motors Mark Rivers
Prev: RE: Problems with soft motors Mark Rivers
Next: Re: Problems with soft motors Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problems with soft motors Kevin Peterson
ANJ, 08 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
