1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about importing data from a Windows PC to a Linux PC
To: Kim SeongBin <[email protected]>
Date: Mon, 17 Sep 2018 03:04:39 +0000
What software do you currently use to read the data from the RS-485 devices on Windows? Is it software you wrote yourself or is it a commercial program?  Do you know what protocols your devices use?
Sent from my iPhone
On Sep 16, 2018, at 7:23 PM, Kim SeongBin <[email protected]<mailto:[email protected]>> wrote:
Hi, Mark
I am a beginner and I am sorry that my question is not clear.
This is the answer to your questions.
__________________________________________________________________
Q: What is the data?  A few scalar values, large arrays, etc.?
A: A few scalar values. gamma and neutron radiation, Temperautre, humidity, etc.
Q: What do you mean by "EPICS is currently installed on Linux PCs"?  Do you mean that you can run EPICS clients on Linux, or are you running EPICS IOCs on Linux?
A: I mean that I can run EPICS clients on Linux.  I have not made EPICS IOCs yet.
Q: What do you mean by "import data from windows PC to linux PC using EPICS"?  Do you mean import to an EPICS client on Linux, or to an EPICS IOC?
A: I mean that I want to create data as EPICS PVs on Windows. Then, I want to get the data Linux clients.
How do I create Windows IOCs?
Thanks in advance
SeongBin Kim
2018년 9월 16일 (일) 오후 11:54, Mark Rivers <[email protected]<mailto:[email protected]>>님이 작성:
Hi SeongBin,
I think the answer to the question depends on what you mean the by the following:
- What is the data?  A few scalar values, large arrays, etc.?
- What do you mean by "EPICS is currently installed on Linux PCs"?  Do you mean that you can run EPICS clients on Linux, or are you running EPICS IOCs on Linux?
- What do you mean by "import data from windows PC to linux PC using EPICS"?  Do you mean import to an EPICS client on Linux, or to an EPICS IOC?
You can create an IOC on Windows that will publish the data as EPICS PVs.  You can then get that data into either the Linux IOCs or Linux clients via EPICS Channel Access.  We do this with lots of Windows IOCs.
From: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> on behalf of Kim SeongBin <[email protected]<mailto:[email protected]>>
Sent: Sunday, September 16, 2018 2:18 AM
To: [email protected]<mailto:[email protected]>
Subject: Question about importing data from a Windows PC to a Linux PC
I am an EPICS beginner.
I have a question in the following situation.
___________         _______________                             ___________
| Linux PC      |        | Windows PC        |  USB to RS485  | Device        |
|___________|       |_______________|  converter          |__________|
The monitoring program is running on the windows PC and is reading the value from the device.
I want to import data from windows PC to linux PC using EPICS.
EPICS is currently installed on Linux PCs and Windows PCs are not installed.
How can I solve this problem?
Thanks in advance,
SeongBin Kim
Re: Question about importing data from a Windows PC to a Linux PC Kim SeongBin
Re: Question about importing data from a Windows PC to a Linux PC Mark Rivers
Prev: Fwd: Question about importing data from a Windows PC to a Linux PC Kim SeongBin
Next: Re: Question about importing data from a Windows PC to a Linux PC Kim SeongBin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
