Dear All, I have a question about how to access the string array data of waveform record in the callback function. In order to read a waveform record, I register a callback function using the ca_create_subscription function. static void eventCallback(struct event_handler_args eha) { chid chid = eha.chid; if (eha.status != ECA_NORMAL) { printChidInfo(chid, "eventCallback"); } else { char *pdata = (char *)eha.dbr; printf("Event Callback: %s = %s\n",ca_name(eha.chid),pdata); } } SEVCHK(ca_create_subscription(DBR_STRING, 1, pvlist[i]->mychid, DBE_VALUE, eventCallback, pvlist[i], &pvlist[i]->myevid), "ca_create_subscription"); But, print the ascii character code of the first element of the string array. How to access the string array data ? When I use caget command line tool, the following message appears. caget Test Test 100 69 80 73 67 83 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 When the eventCallback function is called, the following message appears. Event Callback: Test = 69 Best regards,
| ANJ, 18 Sep 2018 |
Home
News
About
Talk
Base
Modules
Extensions
