1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Ether/IP Driver for AB PLC's: Logging / appdevguide
Date: Fri, 28 Sep 2018 18:45:29 -0400
I'm providing EPICS support for a Phoebus application using the Allen Bradley Ether/IP driver.
I've hit an error condition (Invalid write), and before asking for help with that, I'd like to gather more details.
I've dug around the source and saw a lot of print statements with error messages, which I'm assuming get logged.
I've found this script which appears to start a logger:
ether_ip-2-27/iocBoot/iocether_ip/run_iocLogServer.sh
# This is just for getting an ioc log server to run,
# for testing message capture from the driver.
# Read the appdevguide.
export EPICS_IOC_LOG_FILE_NAME=`pwd`/ioclog.txt
export EPICS_IOC_LOG_PORT=6505
iocLogServer
I've not located the appdevguide, or the binary / src to iocLogServer.
I'd really like to see what's going on with the driver to better understand the source and the application notes (THAP020).
Cheers all,
dpc
Re: Ether/IP Driver for AB PLC's: Logging / appdevguide Kasemir, Kay via Tech-talk
Prev: Re: vxWorks 6.9 stdio.h error Johnson, Andrew N.
Next: Re: Ether/IP Driver for AB PLC's: Logging / appdevguide Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 28 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
