1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: CAUTION: Problem with areaDetector ImageJ PVA viewer
Date: Sat, 29 Sep 2018 22:28:37 +0000
Folks,
I have found a serious issue with the EPICS V4 Java client code which is exposed with the areaDetector ImageJ PVA viewer (EPICS_NTNDA_Viewer.java).
When the areaDetector IOC is not running the ImageJ plugin keeps trying to connect.  I have found that the broadcast search requests have an ever-increasing number of duplicate PVs in them.  The search requests normally only occur at 0.5 Hz or so.  However, as the number of duplicate PVs per search increases, each search requires multiple Ethernet packets.  After a few hours the number of broadcast packets is very large.  I have seen those broadcasts consume >90% of the CPU time on all of my VME IOCs.
It appears that the problem is not in the ImageJ plugin, but rather in the underlying epics-pvaclient Java code.  Marty Kraimer and I are planning to test a fix to that soon.
In the meantime I would discourage people from using the ImageJ EPICS_NTNDA_Viewer, unless you are sure to kill ImageJ when the areaDetector IOC is not running.  Other applications using the epics-pvaclient Java library may also have this problem.
Fix released (Re: CAUTION: Problem with areaDetector ImageJ PVA viewer) Ralph Lange
Prev: Lyncean Technologies Software Position Terri Lahey
Next: Stream device does not recognize a custom record type Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Fix released (Re: CAUTION: Problem with areaDetector ImageJ PVA viewer) Ralph Lange
ANJ, 04 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
