1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: Controlling Eiger 1M with EPICS
Cc: tech-talk <[email protected]>, [email protected], Sumit Kewalramani <[email protected]>
Date: Wed, 3 Oct 2018 12:17:56 -0400
I think that at some point after 1.6.2 Dectris changed "linkN" to "link_N". I think the easiest solution is to update the firmware.
Bruno
On Tue, Oct 2, 2018 at 10:27 PM Mark Rivers <[email protected]> wrote:
Ø  Our Eiger firmware version is 1.6.2.  The version of ADEiger that we are attempting to use had in one of the RELEASE info files the mention of requiring firmware version 1.6.4+.
The ADEiger documentation here http://cars.uchicago.edu/software/epics/eigerDoc.html says that it has been tested with firmware 1.6.4+.  My Eiger 50K has firmware 1.6.6.  So I think it is quite possible that the problem is that you are running older firmware.
Sent: Tuesday, October 2, 2018 7:15 PM
Cc: [email protected]; Sumit Kewalramani <[email protected]>
Hi Mark,
I think I was able to obtain an image using the web interface.  I will verify this the next time I'm at the instrument.  When running the st.cmd command, the light on the back of the Eiger changes from red to green before spewing errors.
I did a little more digging.  Our Eiger firmware version is 1.6.2.  The version of ADEiger that we are attempting to use had in one of the RELEASE info files the mention of requiring firmware version 1.6.4+.  Do you think this could be our issue?  I've downloaded R2-1 which mentions 1.6.2 and am going to attempt to compile it with the areaDetector tree we currently have installed.
Thanks for your help!
On 2018-10-02 18:40 , Mark Rivers Wrote:
Hi Jason,
I had a similar problem with our Eiger 500, but in my case it could only not find link_3 and link_4.  This is an expected error on the Eiger 500K because only link_1 and link_2 exist.  I fixed the driver for the 500K in this commit:
https://github.com/areaDetector/ADEiger/commit/50e13b24226e6eb702bd88a8dab16ed280c99137#diff-d1d617fd8427431b5658f2ef750e0a74
In your case it is not finding any of the links (link_1 through link_4), probably in the eigerDetector::eigerStatus() function.  That does not make sense to me.
Is the detector working otherwise?  Can you collect an image?
From: [email protected] <[email protected]> On Behalf Of Jason A . Pattie
Sent: Tuesday, October 2, 2018 4:19 PM
To: [email protected]
Cc: Sumit Kewalramani <[email protected]>
Subject: Controlling Eiger 1M with EPICS
Hello,
I'm attempting to setup a Dectris Eiger R 1M with EPICS (3.15.5) and have compiled the latest version of asyn, ADSupport, ADCore, and ADEiger driver.  Upon running st.cmd, I receive the following errors:
eigerDetectorConfig("EIG", "10.42.41.10", 0, 0)
RestApi::get: [param=description] server returned error code 404
2018/10/02 15:43:48.583 Param[DESCRIPTION]::baseFetch: [param=description] unable to parse json response
2018/10/02 15:43:48.583 Param[DESCRIPTION]::fetch<string>: [param=DESCRIPTION] underlying baseFetch failed
2018/10/02 15:43:48.583 eigerDetector::eigerDetector: Eiger seems to be uninitialized
Initializing... (may take a while)
RestApi::get: [param=link_1] server returned error code 500
2018/10/02 15:44:07.686 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2018/10/02 15:44:07.686 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
RestApi::get: [param=link_2] server returned error code 500
2018/10/02 15:44:07.689 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2018/10/02 15:44:07.689 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
RestApi::get: [param=link_3] server returned error code 500
2018/10/02 15:44:07.693 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2018/10/02 15:44:07.693 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
2018/10/02 15:44:07.816 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2018/10/02 15:44:07.816 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
2018/10/02 15:44:07.825 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2018/10/02 15:44:07.825 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
2018/10/02 15:44:07.834 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2018/10/02 15:44:07.834 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
epics> eigerDetectorConfig("EIG", "$(EIGERIP)", 0, 0)
2018/10/02 15:44:42.327 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2018/10/02 15:44:42.327 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
2018/10/02 15:44:42.336 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2018/10/02 15:44:42.336 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
2018/10/02 15:44:42.345 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2018/10/02 15:44:42.345 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
2018/10/02 15:44:42.500 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2018/10/02 15:44:42.500 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
2018/10/02 15:44:42.509 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2018/10/02 15:44:42.509 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
2018/10/02 15:44:42.518 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2018/10/02 15:44:42.518 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
If you need any other information, please let me know.
Any help figuring this out would be greatly appreciated.
Thank you.
Jason A. Pattie
User Support Specialist Sr.
Molecular Biosciences/MIM/CSGID
Computational Facility Manager - Structural Biology Facility
Re: RE: Controlling Eiger 1M with EPICS Jason A . Pattie
RE: RE: Controlling Eiger 1M with EPICS Mark Rivers
Prev: Re: Alive module server Steve Kinder - UKRI STFC
Next: Fix released (Re: CAUTION: Problem with areaDetector ImageJ PVA viewer) Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: RE: Controlling Eiger 1M with EPICS Mark Rivers
Next: Re: RE: Controlling Eiger 1M with EPICS Jason A . Pattie
ANJ, 12 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
