To avoid the "Cannot write password" error from the UI, check that the installation folder is writable.
> I tried with new workspace and command line, setting password in file the result below
> css-4.5.0$ ./css -pluginCustomization setting.ini
Use /the/full/path/to/your/settings.ini, not just settings.ini .
From http://cs-studio.sourceforge.net/docbook/ch06.html#sec_cmdline_plugin_customization :
... always provide the full name to the file, even if it is in what you consider the current directory, because the Java runtime that is started by the Eclipse RCP launcher could have a very different idea of its current directory.
If Eclipse does not find your -pluginCustomization file, it is simply ignored, there will be no error message! So if the settings that you think you put into a -pluginCustomization file are not having the desired effect, triple check that you indeed provided the full and correct path to the file.
-Kay
- Re: CSS data browser to MySQL connection J. Lewis Muir
- Re: CSS data browser to MySQL connection Vishnu Patel
- Re: CSS data browser to MySQL connection Kasemir, Kay via Tech-talk
EPICS Collaboration Meeting Registrations Now Open [SEC=UNCLASSIFIED] POZAR, Andraz
<2018>
2025
2026
<2018>
2025
2026
