1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Application Package
To: [email protected]
Date: Fri, 12 Oct 2018 16:23:01 +0200
Hi
I am also very interested in this thread as I am working on a new setup.
I worked with the below described configuration when working with the ESS EPICS setup, but could you please provide some information on how to do this from the "normal base" epics system. All demos and docs I have seen ends up with compiling the ioc binary including the support libraries in the process.
On 2018-10-12 09:37, Ralph Lange wrote:
Other institutes are using an NFS mounted repository of all applications and shared libraries and a database of versions of tested combinations of these, and load device support and EPICS modules dynamically from the startup script of the IOC. This also needs a careful design and serious building infrastructure in the background, but maybe requires less upfront work and learning compared to the first option.
Best
    Bo
Re: EPICS Application Package Ralph Lange
EPICS Application Package Vikram Bhagat via Tech-talk
Prev: RE: EPICS Application Package Engbretson, Mark S.
Next: Re: EPICS Application Package Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
