1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Camera Recommendations [SEC=UNCLASSIFIED]
From: "Pearson, Matthew R. via Tech-talk" <[email protected]>
To: "POZAR, Andraz" <[email protected]>
Date: Wed, 17 Oct 2018 14:46:07 +0000
I’ve recently purchased two FLIR/Point Grey GigE Flea3 cameras. I’ve not seen them freeze, but I’ve only run them for hours or a few days, using the ADPointGrey driver (flycapture library) on RHEL7. I hope to get more experience with them over the coming months.
We do have a couple of AVT Manta G-125 cameras that we have ran for months with no issues (using ADProsilica on RHEL6 and RHEL7).
Cheers,
Matt
> On Oct 16, 2018, at 6:01 PM, POZAR, Andraz <[email protected]> wrote:
> Hi Mark,
> Thank you for recommendation, however, we have tried using BFLY-PGE-13S2M-CS with adSpinnaker on Ubuntu 16 and FL3-GE-13S2M-CS with adPontGrey on Centos 7 but both of them "freeze" after running smoothly for some time. They become unresponsive and an IOC reboot is required in some cases even power cycle of the camera.  We're running them at toughly 1 Hz so they should get overworked.
> At this stage we're looking at potential alternatives or any kind of advice if someone has had similar experience with those cameras?
> Cheers,
> Andraz
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Tuesday, October 16, 2018 10:45 PM
> To: POZAR, Andraz <[email protected]>; [email protected]
> Hi Andraz,
> The Point Grey Blackfly cameras will meet your specifications:
> https://www.ptgrey.com/blackfly-gige-poe-cameras
> Here are 2 examples:
> BFLY-PGE-13S2M-CS
> 1/3 inch, global shutter, 1288x964 pixels
> 3.75 micron pixels
> 66% QE, 11 e- read noise, 9339 e- full well
> 58 dB dynamic range
> 30 FPS
> POE
> $345
> The following model has significantly better QE, read noise, and dynamic range in a somewhat larger format:
> BFLY-PGE-23S6M-C
> 1/1.2" sensor, global shutter, 1920x1200 pixels
> 5.86 micron pixels
> 80% QE, 7 e- read noise, 33105 e- full well
> 73 dB dynamic range
> 41 FPS
> POE
> $495
> Either camera can be used with 3 areaDetector drivers:
> ADPointGrey (Windows, Linux RHEL 7 or higher) aravisGigE (Linux, most any version) ADSpinnaker (Windows, Linux Ubuntu 16 and higher)
> Mark
> ________________________________
> From: [email protected] <[email protected]> on behalf of POZAR, Andraz <[email protected]>
> Sent: Tuesday, October 16, 2018 12:44 AM
> To: [email protected]
> Subject: Camera Recommendations [SEC=UNCLASSIFIED]
> Hi all,
> We're looking into replacing our old Firewire cameras with Ethernet ones and we'd be interested in any suggestions and experiences you have had with different camera models.
> Some requirements:
> -          1/3 inch, global shutter, mono sensor at roughly 1300 x 900 resolution
> -          Good quantum efficiency and low noise
> -          Roughly 4 microns pixel size
> -          Ethernet
> -          Preferably POE
> -          areaDetector support
> Cheers,
> Andraz Pozar
> Controls Engineer
> Australian Synchrotron
> Tel
> Email
> Web
> +61 3 8540 5387
> [email protected]<mailto:[email protected]>
> www.ansto.gov.au<http://www.ansto.gov.au/>
> [fb]<http://www.facebook.com/DiscoverANSTO> [tw] <https://twitter.com/ANSTO>  [ln] <http://www.linkedin.com/company/ansto>  [yt] <http://www.youtube.com/user/ANSTOVideos>
> [ansto]
> Important: This transmission is intended only for the use of the intended addressee. It is confidential to the intended addressee and may contain privileged information and or copyright material. If this email is not intended for your attention, any use, printing, storage, reproduction or further disclosure of this communication (including all attachments) is strictly forbidden. If you have received this transmission in error, please notify me by telephone or email and immediately delete all copies of this transmission as well as any attachments.
Camera Recommendations [SEC=UNCLASSIFIED] POZAR, Andraz
Re: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
RE: Camera Recommendations [SEC=UNCLASSIFIED] POZAR, Andraz
Prev: RE: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
Next: RE: Camera Recommendations [SEC=UNCLASSIFIED] Engbretson, Mark S.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Camera Recommendations [SEC=UNCLASSIFIED] Wayne Lewis
Next: Weird crash in seq record Dirk Zimoch
ANJ, 17 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
