1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Beacon like connection attempts from caGateway
To: EPICS Tech Talk <[email protected]>
Date: Sat, 27 Oct 2018 22:30:40 +0200
Hello Bo,
You are right: port 5065/udp traffic are CA beacon messages, which are sent every 15 seconds (unless configured otherwise).
What is the server IP address (-sip <addr>) of your Gateway? If you don't configure a CA server to bind to an explicit IP, it will bind to all available network interfaces, including the one that the Gateway uses to connect to its clients (the machine called "cagw" in your case). Obviously, the CA server will also send beacons on all interfaces it binds to.
I.e., not setting the server IP of a Gateway would explain the behavior you are seeing.
Cheers,
~Ralph
Re: Beacon like connection attempts from caGateway Bo Jakobsen
Prev: Question about running CSS from eclipse oxygen lzf neu
Next: Status of caml&webCA 黄佳伟
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Beacon like connection attempts from caGateway Bo Jakobsen
Next: Re: Beacon like connection attempts from caGateway Bo Jakobsen
ANJ, 29 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
