I'd like to announce the availability of P4P (PVAccess for Python)
library version 3.0.0. Quite a bit of work has been done since the
previous 1.0 release. Thanks to DLS for supporting this work.
https://mdavidsaver.github.io/p4p/
The headline features are support for running PVA servers, interop
with the asyncio and cothread concurrency libraries, support for
Windows and OSX* as well as Linux, and packaging via pypi.org.
The last point means that investigating P4P starts with a simple:
> pip install p4p
No other setup is required.
See the quickstart section for where to go from there.
https://mdavidsaver.github.io/p4p-dev/starting.html
Alternately, P4P can be built as an EPICS module in the usual way.
https://github.com/mdavidsaver/p4p/releases/tag/3.0.0
* I'm interested in OSX test results as I have a report
of a strange failure from one user.
- Re: P4P release 3.0.0 Heinz Junkes
RE: Current Source / Power supply suggestion Stubbs Scott Allen (PSI)
NSLS2 EPICS trainings by Tim Mooney Gofron, Kazimierz via Tech-talk
<2018>
2025
2026
Open Computer Engineering position at PPPL Greg Tchilinguirian via Tech-talk
<2018>
2025
2026
