1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: areaDetector ADViewers R1-2 available
To: tech-talk <[email protected]>
Date: Sun, 11 Nov 2018 21:48:14 +0000
ADViewers R1-2 is now available.  This is from the release notes:
### EPICS_NTNDA_Viewer
* Changed connection management to use callbacks rather than polling.  Thanks to Marty Kraimer for this.
* Previously this viewer was incorrectly treating signed 8-bit and 16-bit images as unsigned.
  Changed so that signed 8-bit and 16-bit data are now converted to float, so ImageJ correctly displays negative values.
  Conversion to float is required because the ImageJ ByteProcessor and ShortProcessor only support unsigned integers.
* Improved the status messages in the display to show when the display is stopped, and when connect and
  disconnect events occur.
### EPICS_AD_Viewer
The home page is here:
https://github.com/areaDetector/ADViewers
The documentation is here:
http://cars.uchicago.edu/software/epics/areaDetectorViewers.html
The release notes are here:
https://github.com/areaDetector/ADViewers/blob/master/RELEASE.md
Prev: Re: P4P release 3.0.0 Heinz Junkes
Next: areaDetector ADSupport R1-5 released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: IOC for OMEGA WISE 7118Z John . Holt
ANJ, 12 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
