1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Questions about EPICS_PVA_ADDR_LIST
To: tech-talk <[email protected]>
Date: Tue, 13 Nov 2018 14:32:03 +0000
I was under the impression that no environment variables should need to be set in order for pvAccess to find PVs on the local subnet.  However, this does not seem to be working with base 7.0.x (master as of a few months ago).
By default on both my Linux and Windows systems no EPICS_PVA_* environment variables are set.
If I run the IOC on Linux then this is what I see with pvinfo from Windows:
C:\phoebus-0.0.1-win\phoebus-0.0.1>h:\epics\base\bin\windows-x64-static\pvinfo 13SIM1:Pva1:Image
2018-11-13T08:12:23.358 No broadcast addresses found or specified - empty address list!
[13SIM1:Pva1:Image] failed to get channel introspection data
If I set EPICS_PVA_ADDR_LIST to the broadcast address of the subnet it works:
C:\phoebus-0.0.1-win\phoebus-0.0.1>set EPICS_PVA_ADDR_LIST=164.54.160.255
CHANNEL  : 13SIM1:Pva1:Image
STATE    : CONNECTED
ADDRESS  : 164.54.160.82:59335
epics:nt/NTNDArray:1.0
    union value
        boolean[] booleanValue
        byte[] byteValue
        short[] shortValue
        int[] intValue
        long[] longValue
        ubyte[] ubyteValue
        ushort[] ushortValue
        uint[] uintValue
        ulong[] ulongValue
        float[] floatValue
        double[] doubleValue
If I run pvinfo on Linux where the IOC is running then it works without setting EPICS_PVA_ADDR_LIST.  Thus it at least finds PVs on localhost.
corvette:~/devel/areaDetector/ADSupport>printenv | grep EPICS_PVA
corvette:~/devel/areaDetector/ADSupport>/usr/local/epics/base-7.0.1/bin/linux-x86_64/pvinfo 13SIM1:Pva1:Image
STATE    : CONNECTED
    union value
        byte[] byteValue
        short[] shortValue
        int[] intValue
        long[] longValue
        ubyte[] ubyteValue
        uint[] uintValue
        ulong[] ulongValue
        float[] floatValue
Now I run the IOC on Windows.
Running pvinfo on the local Windows machine:
If I undefine EPICS_PVA_ADDR_LIST it does not work.  Thus it does not even find PVs on localhost.
2018-11-13T08:20:24.858 No broadcast addresses found or specified - empty address list!
If I define EPICS_PVA_ADDR_LIST it works fine.
STATE    : CONNECTED
ADDRESS  : 164.54.160.15:5075
    union value
        byte[] byteValue
        short[] shortValue
        int[] intValue
        long[] longValue
        ubyte[] ubyteValue
        uint[] uintValue
        ulong[] ulongValue
        float[] floatValue
Running pvinfo on Linux it works fine without defining EPICS_PVA_ADDR_LIST.
STATE    : CONNECTED
    union value
        byte[] byteValue
        short[] shortValue
        int[] intValue
        long[] longValue
        ubyte[] ubyteValue
        uint[] uintValue
        ulong[] ulongValue
        float[] floatValue
So it appears that I need to set EPICS_PVA_ADDR_LIST on Windows for pvinfo or pvget to work.
However, when I run phoebus (the new version of CSS) I can display that PV fine even without setting EPICS_PVA_ADDR_LIST.
Re: Questions about EPICS_PVA_ADDR_LIST Mark Rivers
Re: Questions about EPICS_PVA_ADDR_LIST Michael Davidsaver
Prev: areaDetector ADSupport R1-5 released Mark Rivers
Next: Re: Questions about EPICS_PVA_ADDR_LIST Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 13 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
