1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ADSimDetector and ADURL - runtime issues with FFT and HDF5
To: "Heesterman, Peter J" <[email protected]>, "Engbretson, Mark S." <[email protected]>
Cc: "EPICS Tech-Talk \([email protected]\)" <[email protected]>
Date: Tue, 27 Nov 2018 13:54:10 +0000
Hi Peter,
> HDVView 2.11.0 is the version that installs on Ubuntu 18.04, by means of apt-get.
> May I ask which Linux version you’re using?
> In order to get the newer version, I have built 2.14 from sources.
> (I eschewed the Centos distribution, that the HDF group provide).
I am using Centos7.  I could not find a yum package for HDFView, so I also built it from source.
>> NDPluginDriver::connectToArrayPort Error calling pasynManager->connectDevice to array port FFT1 address 0, status=3, error=asynManager:connectDevice port FFT1 not found.
Sorry, I just found I was getting the same error and had not noticed it.
The problem is that the NDStdArraysConfigure command above is coming before this line:
< $(ADCORE)/iocBoot/commonPlugins.cmd
This means that the FFT1 port does not yet exist when this command is executed.  I have fixed st_base.cmd in both iocSimDetector and iocHDF5Test.
> I’m not sure I fully understand the name binding and correlation between these lines of the script?
>            dbLoadRecords("NDStdArrays.template", "P=13SIM1:,R=image2:,PORT=Image2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM2,TYPE=Float64,FTVL=DOUBLE,NELEMENTS=12000000")
>             NDStdArraysConfigure("Image2", 3, 0, "FFT1", 0)
>             NDFFTConfigure("FFT1", 3, 0, "SIM1", 0, 0, 0, 0, 0, 5)
I also see that the order of the dbLoadRecords and NDStdArrays commands is not in the logical order.  The port should be created first, although it is not an error to do it this way.  I have fixed that as well. Port Image2 was told to gets its data from SIM2 in the first command, and from port FFT1 in the second command.  The first command will "win" because it is executed later, during iocInit. This is confusing and I have changed them both to FFT1.
The order is now
NDFFTConfigure("FFT1", 3, 0, "SIM1", 0, 0, 0, 0, 0, 5)  ; This is from commonPlugins.cmd
dbLoadRecords("NDStdArrays.template", "P=13SIM1:,R=image2:,PORT=Image2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FFT1,TYPE=Float64,FTVL=DOUBLE,NELEMENTS=12000000")
The bindings are:
Port FFT1 gets its data from port SIM1
Port Image2 gets its data from port FFT1
Port Image2 again gets its data from port FFT1
Was the HDF5 plugin getting its data directly from the camera driver, or from some other plugin?
I will set up a simDetector with the same dimensions as your detector and try to reproduce the issue.  I'll post another message with the results.
Sent: Tuesday, November 27, 2018 6:11 AM
To: Mark Rivers; Engbretson, Mark S.
Cc: EPICS Tech-Talk ([email protected])
Subject: RE: ADSimDetector and ADURL - runtime issues with FFT and HDF5
Hi Mark,
>> NDPluginStdArrays is not optional, it is always built as part of ADCore.
Sorry for the misunderstanding.
I (incorrectly) connected your comment about “NDPluginStdArrays” with:
#NDDRIVERSTDARRAYS=$(AREA_DETECTOR)/NDDriverStdArrays
>> hdfview, you are running 2.11.0, I am running 2.14.0
Now I’m able to open the data from a recorded data file (this from the URL module), but the image isn’t recognisable.
See the screen shot attached (you can also see the ImageJ view across my desk).
Do you have any ideas about this?
I still have the error in the SimDetector module, both on Ubuntu and Windows.
Many thanks,
Peter.
Sent: 20 November 2018 18:22
To: Heesterman, Peter J <[email protected]>; Engbretson, Mark S. <[email protected]>
Cc: EPICS Tech-Talk ([email protected]) <[email protected]>
  *   The module is commented out in EXAMPLE_RELEASE.local, and I hadn’t appreciated that it was a dependency, when I carried out the install.
  *   I have corrected that.
I’m not sure what you mean.  What module is commented out in EXAMPLE_RELEASE.local?  NDPluginStdArrays is not optional, it is always built as part of ADCore.
  *    Does this suggest that I’m missing some aspect of hdfview, where I am still unable to view data...?
The fact that h5dump works fine on your HDF5 file suggests that perhaps your version of hdfview is the problem.  I am running 2.14.0, you are running 2.11.0.  Try updating.
From: Heesterman, Peter J <[email protected]<mailto:[email protected]>>
Sent: Tuesday, November 20, 2018 12:11 PM
To: Mark Rivers <[email protected]<mailto:[email protected]>>; Engbretson, Mark S. <[email protected]<mailto:[email protected]>>
Cc: EPICS Tech-Talk ([email protected]<mailto:[email protected]>) <[email protected]<mailto:[email protected]>>
Hi Mark,
>> I think your problem with the ImageJ display is that you have not enabled NDPluginStdArrays.
Ah .. OK, thank you.
I am now able to view the simulated image (13SIM:image1).
>> You error about the FFT is coming before the IOC has really even started
Yes, this is odd.
I’m assuming that it originates with either of:
            dbLoadRecords("NDFFT.template", "P=13SIM1:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=SIM1, NAME=FFT1, NCHANS=1024")
I’m not sure how much importance can be attached to the sequence of log messages in a threaded application.
In any case, I still have this error, do you have any ideas?
>> h5dump on the HDF5 file, and put it into test5_001.txt.  What does that file look like for you?
It is attached.
It looks pretty much like yours, to me.
Many thanks,
Peter.
From: Mark Rivers <[email protected]<mailto:[email protected]>>
Sent: 19 November 2018 21:25
To: Heesterman, Peter J <[email protected]<mailto:[email protected]>>; Engbretson, Mark S. <[email protected]<mailto:[email protected]>>
medmInit: Unable to load font widgetDM_48
  Trying default (fixed) instead
medmInit: Unable to load font widgetDM_60
2018/11/19 18:31:31.558 NDPluginDriver::connectToArrayPort Error calling pasynManager->connectDevice to array port FFT1 address 0, status=3, error=asynManager:connectDevice port FFT1 not found
< envPaths
epicsEnvSet("IOC","iocHDF5Test")
You error about the FFT is coming before the IOC has really even started, right after your medm widget messages.  I have no idea how that can happen,  since it has not even called dbLoadDatabase yet.  How can the pluginDriver possibly be generating an error message, it is not even running yet?  Is this message perhaps from another IOC, or the previous IOC as it exits?
For your HDF5 problem, this is test5.sh:
corvette:simDetectorIOC/iocBoot/iocHDF5Test>more test5.sh
caput 13SIM1:cam1:SizeX 10
caput 13SIM1:cam1:SizeY 10
caput 13SIM1:cam1:AcquireTime .001
caput 13SIM1:cam1:AcquirePeriod 0.1
caput 13SIM1:cam1:ImageMode "Continuous"
caput 13SIM1:cam1:ArrayCallbacks "Enable"
caput -S 13SIM1:cam1:NDAttributesFile "./test5_attributes.xml"
caput 13SIM1:cam1:Acquire 1
caput 13SIM1:HDF1:EnableCallbacks Enable
caput -S 13SIM1:HDF1:FilePath "./"
caput -S 13SIM1:HDF1:FileName "test5"
caput -S 13SIM1:HDF1:FileTemplate "%s%s_%3.3d.h5"
caput -S 13SIM1:HDF1:XMLFileName "./test5_layout.xml"
caput 13SIM1:HDF1:AutoIncrement 1
caput 13SIM1:HDF1:FileNumber 1
caput 13SIM1:HDF1:FileWriteMode "Stream"
caput 13SIM1:HDF1:NumCapture "0"
caput 13SIM1:HDF1:Capture 1
sleep 3
caput 13SIM1:HDF1:Capture 0
sleep 5
h5dump test5_001.h5 > test5_001.txt
Note that the last thing it does is to run h5dump on the HDF5 file, and put it into test5_001.txt.  What does that file look like for you?  Mine starts like this:
HDF5 "test5_001.h5" {
GROUP "/" {
   GROUP "entry" {
      ATTRIBUTE "NX_class" {
         DATATYPE  H5T_STRING {
            STRSIZE 7;
            STRPAD H5T_STR_NULLTERM;
            CSET H5T_CSET_ASCII;
            CTYPE H5T_C_S1;
         DATASPACE  SCALAR
         DATA {
         (0): "NXentry"
      ATTRIBUTE "signal" {
            STRSIZE 4;
            CTYPE H5T_C_S1;
         DATASPACE  SCALAR
         DATA {
         (0): "data"
      DATASET "AD_template_ID" {
            STRSIZE 58;
            CTYPE H5T_C_S1;
         DATASPACE  SIMPLE { ( 1 ) / ( 1 ) }
         DATA {
         (0): "$Id: pilatus_layout.xml 8015 2015-02-24 18:28:27Z jemian $"
Please send me the version created on your system.
Sent: Monday, November 19, 2018 1:06 PM
Hi Mark,
>> It looks like from your log file that the FFT error message is actually part of a comment in your startup script.  I don’t see how this can be a real error message, since no asyn ports have been created yet at that point in the startup script.
I assume this is a threading artifact of simultaneous logging, which jumbles and obfuscates the text output, particularly when stdout and stderr are redirected to a file.
I’ve removed the comments from the start-up script, (as best I can) where this happens, so as to make the error clearer to see.
>> Did you look at the ImageJ log file?
Yes, there are no errors shown there.
Just no image display...
I attach screen shots with the requested information, as best I can.
Also screen shot of hdvview showing the resulting file, no attribute nodes (quite unlike the screen shot you sent me!).
Cheers,
Peter.
Sent: 19 November 2018 15:51
  *   NB, data visualisation with ImageJ works for me with the ADURL module with the values given, but fails for the SimDetector module (with or without attempting to use HDF5).
Please send screen shots of the following:
  *   simDetector main screen
  *   simDetector setup screen
  *   commonPlugins screen
  *   EPICS_AD_Viewer ImageJ screen
Sent: Monday, November 19, 2018 9:31 AM
To: Engbretson, Mark S. <[email protected]<mailto:[email protected]>>; Mark Rivers <[email protected]<mailto:[email protected]>>
Hi Mark(s),
I am using simDetector 2-8, which I believe is the most recent.
My comment about the st.cmd script referred to the iocHDF5Test sub-folder (which I was seeking to exercise), and not the main iocSimDetector folder (where the script is correct).
- I’m sorry that was unclear.
Are you talking about EPICS_CA_MAX_ARRAY_BYTES?
It is set as an environment variable which is applied to shells through /etc/profile.d/custom.sh.
Cheers,
Peter.
From: Engbretson, Mark S. <[email protected]<mailto:[email protected]>>
Sent: 19 November 2018 15:04
But did it make any difference? You might have to set this both in the ADURL and SIMDetector soft IOC st,cmd *AND* in for environment for IMAGEJ to work.
Sent: Monday, November 19, 2018 8:59 AM
Hi Mark,
I have the latest sources.
My comment about the paths refers to the iocHDF5Test sub-folder that I was working with, not the iocSimDetector folder (where it’s correct).
I’m sorry this wasn’t clear.
I has set EPICS_CA_MAX_ARRAY_BYTES to 30000000 which is overkill I think, so I reduced it to 10000000.
Cheers,
Peter.
Sent: 19 November 2018 14:44
I don’t think that you have the latest sources for ADSimDetector since the paths are correct on the sources that I have.
If ImageJ   doesn’t work, chances are the value for
Is either not set or set to be a value too small for the actual image data.
From: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> On Behalf Of Heesterman, Peter J via Tech-talk
Sent: Monday, November 19, 2018 8:24 AM
To: EPICS Tech-Talk ([email protected]<mailto:[email protected]>) <[email protected]<mailto:[email protected]>>
Subject: ADSimDetector and ADURL - runtime issues with FFT and HDF5
I’m seeking to use these modules with HDF5 data archiving.
Accordingly, I’ve been looking at the iocHDF5Test within ADSimDetector, and focused on test5.sh.
I’m working with an Ubuntu 18.04 VM.
I have:
    areaDetector and ADCore R3-3-2
    ADSupport R1-5
  ADViewers R1-2
    ADURL R2-2
    Asyn4-33
    Base 3.15.6
There are some issues that I need to raise:
a. st.cmd in ADSimDetector hasn’t been updated to reflect module paths – in particular lines like
        dbLoadRecords("$(ADCORE)/db/simDetector.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1"), where the file is no longer in ADCore.
    This is easily corrected. Actually, I believe st_base.cmd from iocSimDetector can just be used.
b. When I run the sim detector and try to visualise with ImageJ, I get green on both 13SIM1:image1 and 13SIM1:image2.
    But, I don’t get any image displayed for either.
c. I note an error:
    Could my (b) have anything to do with this error?
    I understand that image2 would be the FFT of the simulated data generated for image1?
d. I am able to create a HDF5 file (for either ADSimDetector or ADURL) as requested by the test5.sh script (I cloned the logic of this for the ADURL module).
    These files are large (>~100MB), and clearly contain the simulated and URL data, respectively.
    I’m able to open the file(s) with the hdfview application (after closing the IOC, to avoid any file write/read share issues).
    But, I’m unable to view any of the data because there are no attribute nodes under the ‘test5_001.h5’ root, in the viewer.
    Viewing the ‘properties’ on the ‘test5_001.h5’ node in hdfview, shows no attributes and no datasets.
    I refer to http://cars9.uchicago.edu/software/epics/NDFileHDF5.html , which I’ve studied in some detail.
I am able to visualise data from the ADURL module, quite normally.
What is it that I’m missing?
Many thanks,
Peter.
ADSimDetector and ADURL - runtime issues with FFT and HDF5 Heesterman, Peter J via Tech-talk
RE: ADSimDetector and ADURL - runtime issues with FFT and HDF5 Heesterman, Peter J via Tech-talk
RE: ADSimDetector and ADURL - runtime issues with FFT and HDF5 Mark Rivers via Tech-talk
Prev: https://ics-web.sns.ornl.gov/css/nightly/ down? Kasemir, Kay via Tech-talk
Next: RE: ADSimDetector and ADURL - runtime issues with FFT and HDF5 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ADSimDetector and ADURL - runtime issues with FFT and HDF5 Heesterman, Peter J via Tech-talk
ANJ, 27 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
