Hi Mark,
Thunderbird has
* "Reply List" to reply it to [email protected].
* "Reply" to reply to you
* "Reply All" to reply to you and tech-talk
I added my ess email account into tech-talk to figure out what a
problem is now. From this email, I can check what it will be.
I will let you know after my test.
Best,
Han
On 11/28/18 11:19 PM, Mark Rivers via Tech-talk wrote:
Folks,
Recently Argonne required changing the mail headers for mailing lists
like tech-talk and core-talk to improve security.
I am now having a problem when I want to reply to a tech-talk or
core-talk message.
Prior to this change when I did “Reply All” it sent a reply to both the
original sender and the list. If I did “Reply” it went only to the sender.
Now when I do either “Reply All” or “Reply” it goes only to the sender,
not to the list. I am seeing this behavior when using Outlook, Outlook
Web client, and the Mail application on an iPhone. In the mail
application on the iPhone it does not even list “Reply All” as an
option, only “Reply”. I find this quite inconvenient, because I need to
remember to add “tech-talk” even if I do Reply All.
Have others seen this behavior? Is there some setting in Outlook which
can be used to allow “Reply All” to also send to the list?
Andrew Johnson reports that the Thunderbird e-mail client does work
correctly, Reply All goes to the list as well.
- Question about this mailing list Mark Rivers via Tech-talk
Re: Question about this mailing list Ivashkevych, Oksana via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
