1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about this mailing list
To: Hinko Kocevar <[email protected]>
Date: Fri, 30 Nov 2018 12:35:01 +0000
This is what I see with IOS 12.1. It is not working, I don't see Reply All, only Reply.
I don't know much about mail, but could the difference be that my Mail App is using a Microsoft Exchange Server?
Sent: Friday, November 30, 2018 1:25 AM
To: Mark Rivers
Cc: Ivashkevych, Oksana; J. Lewis Muir; [email protected]
No issues here.. IOS 12.0, Mail app. I get to see Reply all option when trying to reply.
[image1.png]
//hinko
Sent from my iPhone
On 30 Nov 2018, at 01:12, Mark Rivers via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi Oksana,
What mail app are you running on the iPhone?  Both Lewis and I found that the iOS Mail App did not work.  You message sounds like you have Outlook for iOS?
Andrew found yesterday that office 365 mail did not work.
From: Ivashkevych, Oksana <[email protected]<mailto:[email protected]>>
Sent: Thursday, November 29, 2018 4:54 PM
To: Mark Rivers <[email protected]<mailto:[email protected]>>; 'J. Lewis Muir' <[email protected]<mailto:[email protected]>>
Cc: [email protected]<mailto:[email protected]>
Hi Mark and Lewis,
I have an iPhone, use office 365 outlook version 2.93.0 and do have both options. I have sent a test email from my phone before to the tech talk using reply all option and received one from tech talk as well. I also checked on aps tech talk page that the mail I received wasn’t a glitch.
As I thought further the only difference is I didn’t upgrade my OS. I still have 11.4.1.
I can easily share the screen shot because I am getting a new phone and most likely the problem discussed.
Oksana
[Image]
Oksana
Get Outlook for iOS<https://aka.ms/o0ukef>
Sent: Thursday, November 29, 2018 17:28
To: 'J. Lewis Muir'
Subject: RE: Question about this mailing list
Hi Lewis,
Thanks for the thoughtful reply. I also found that Reply All is not even an option for tech-talk messages received on an iPhone.
-----Original Message-----
From: J. Lewis Muir <[email protected]<mailto:[email protected]>>
Sent: Thursday, November 29, 2018 3:26 PM
Cc: [email protected]<mailto:[email protected]>; [email protected]<mailto:[email protected]>
On Thu, Nov 29, 2018 at 11:21 AM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
> Here are the complete headers of that message as retrieved from Outlook:
[snip]
> Note that I was mistaken, there is a To: field, it is just higher up in the header and I missed it.
> Note also that in this message To: and From: are not the same, unlike what Ralph said.
> To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
> From: =?gb2312?B?y+/M7NCl?= via Tech-talk <[email protected]<mailto:[email protected]>>
> Reply-To: =?gb2312?B?y+/M7NCl?= <[email protected]<mailto:[email protected]>>
> Sender: <[email protected]<mailto:[email protected]>>
Your copy of the email and mine are essentially identical after I remove Received headers and such:
--- muir-header-filtered.txt 2018-11-29 11:58:51.000000000 -0600
+++ rivers-header-filtered.txt 2018-11-29 12:03:59.000000000 -0600
@@ -25,6 +25,10 @@
<mailto:[email protected]?subject=subscribe>
-Sender: [email protected]<mailto:[email protected]>
+Sender: <[email protected]<mailto:[email protected]>>
Errors-To: [email protected]<mailto:[email protected]>
-Return-Path: <[email protected]<mailto:[email protected]>>
+Return-Path: [email protected]<mailto:[email protected]>
+X-MS-Exchange-Organization-Network-Message-Id:
fef35cc2-4dfc-4e60-74fe-08d655de68f9
+X-MS-Exchange-Organization-AuthSource: carsmail.CARS.APS.ANL.GOV<http://carsmail.CARS.APS.ANL.GOV>
+X-MS-Exchange-Organization-AuthAs: Anonymous
+X-MS-Exchange-Transport-EndToEndLatency: 00:00:00.2031686
So, in mine, I don't have the angle brackets around the Sender and Return-Path addresses; that doesn't matter. And I don't have the
X-MS-Exchange-* fields; that doesn't matter either.
This tells me the difference is in the MUA. Using Gmail, if I click the "Reply to all" button for that email, it creates a reply with the following header fields:
For you with Outlook, it doesn't do that.
And I just tried with iOS 12.1 Mail, and it doesn't do that either: I tap the Reply button and the only reply choice is "Reply"; there is no "Reply All", so it's a pain to reply-all from iOS Mail.
As you alluded to, I think this change in behavior may be due to Argonne's email changes, DMARC in particular. Andrew, or whoever the list administrator is, would probably know. Specifically, it seems that Mailman, the mailing list manager software for the Tech-Talk list, is rewriting the header as follows.
The field
becomes two fields
From: [name] via Tech-Talk <[email protected]<mailto:[email protected]>>
Reply-To: [name] [email-address]
I think this rewrite is causing the reply-all function of some MUAs (e.g., Outlook and iOS Mail) to not work correctly.
It would be helpful to know exactly how Outlook and iOS Mail determine the recipients for a reply-all. Maybe someone has documented it somewhere; I don't know.
Maybe Outlook and iOS Mail honor a Mail-Followup-To or Mail-Reply-To field, and the problem could be solved by making the mailing list manager software add one or both of those fields to the header of any Tech-Talk email it sends; I have no idea.
Or maybe there's a mailing list manager software option that could be tweaked. Based on the X-Mailman-Version header field, the Tech-Talk list is being managed by Mailman 2.1.12. That is the stable 2.x series version, but there is a stable 3.x series version too: Mailman 3.2.0. In 3.2.0, I see an interesting option "reply_goes_to_list" at
https://mailman.readthedocs.io/en/latest/src/mailman/handlers/docs/dmarc-mitigations.html
that says
reply_goes_to_list
If this is set to other than no-munging of Reply-To:, the original
From: goes in Cc: rather than Reply-To:. This is intended to make
MUA functions of reply and reply-all have the same effect with
messages to which mitigations have been applied as they do with
other messages.
I wonder if using this option would make the rewrite of
become
Cc: [name] [email-address]
and if that would make the reply-all function of Outlook and iOS Mail work again.
Yet another approach is to, if you're willing and able to insert a header rewriting program into your local mail delivery pipeline, rewrite the header back to how it was before the DMARC changes. That is, for any Tech-Talk mailing list message, rewrite
Reply-To: [name] [email-address], [original-reply-to]
back to
Reply-To: [original-reply-to]
But if there was a Reply-To field in the original, then I don't know exactly how the first rewrite works; hopefully it adds to the Reply-To field address list and doesn't just overwrite it. If it overwrites it, then there's no way to recover the original. If it prepends or appends, then you can just undo whatever it does to rewrite back to the original.
Lewis
JPEG image
PNG image
Attachment: IMG_3936.PNG
Description: IMG_3936.PNG
Question about this mailing list Mark Rivers via Tech-talk
Re: Question about this mailing list Ralph Lange via Tech-talk
Re: Question about this mailing list Mark Rivers via Tech-talk
Re: Question about this mailing list J. Lewis Muir via Tech-talk
RE: Question about this mailing list Mark Rivers via Tech-talk
Re: Question about this mailing list Ivashkevych, Oksana via Tech-talk
Re: Question about this mailing list Hinko Kocevar via Tech-talk
Prev: Re: Fwd: Re: streamdevice I/O Intr Ralph Lange via Tech-talk
Next: RE: ADMythen --acquisition issues Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about this mailing list Hinko Kocevar via Tech-talk
Next: Re: Question about this mailing list Mark Rivers via Tech-talk
ANJ, 30 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
