1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Fw: Build failure when compiling synApps from source
Date: Tue, 11 Dec 2018 16:50:36 +0000
Sent: Tuesday, December 11, 2018 10:50 AM
To: Iain Marcuson
Subject: Re: Build failure when compiling synApps from source
What happens when you build other synApps modules that have SNL program (optics, motor, asyn, mca, etc.)?  Do they all fail the same way?  Did the seq code itself build without errors?  It build lots of .st programs.
From: [email protected] <[email protected]> on behalf of Iain Marcuson via Tech-talk <[email protected]>
Sent: Tuesday, December 11, 2018 10:38 AM
To: [email protected]
Subject: Build failure when compiling synApps from source
I am attempting to build EPICS natively on an ARM platform running Linux.  EPICS base installs fine, but synApps fails when building (make release followed by make) SSCAN with the following error:
make[4]: *** No rule to make target `scanProg.o', needed by `libscanProgress.a'.  Stop.
snc is installed in the installation, and I have tried manually including the sequencer RULES_BUILD file.  My configuration is as below
-OS Debian 7.11
-System: 32-bit ARM, EPICS_HOST_ARCH=linux-arm
-Base from launchpad, November 30, commit 0649a2f1
-SynApps 6.0
-Base installed to /opt/epics
-SynApps SUPPORT var set to source directory, EPICS_BASE set to /opt/epics
-snc binary in /opt/epics/bin/linux-arm
-PATH, LD_LIBRARY_PATH, and HOST_ARCH appropriately set
Are there other configurations I need to change, or something else entirely?
Thank you,
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com<http://www.sydortechnologies.com/>
Skype: [email protected]
FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
Prev: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
Next: build caQtDM Brands Helge (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
ANJ, 11 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
