1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: motor R6-11 released
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 12 Dec 2018 17:30:30 +0000
Release 6-11 of the motor module is now available.
The release notes can be found on github:
   https://github.com/epics-modules/motor/releases/tag/R6-11
This will be the last non-bugfix release of the motor module before
R7-0, which is when the drivers will be moved to their own modules.
Kevin
Prev: Re: record field max length? Johnson, Andrew N. via Tech-talk
Next: Symantec legacy certificate Konrad, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: record field max length? William Kirstaedter via Tech-talk
ANJ, 14 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
