Subject: |
modules/ca/src/perl cc1: error: ‘-fcf-protection=full’ on first build of base |
Peter Milne via Tech-talk <[email protected]> |
To: |
Date: |
Thu, 3 Jan 2019 09:33:15 +0000 |
Hello Tech-talk
Clean build fails first try on Fedora 28
Same result on 3.16
It's easily fixed, but is no one else using Fedora? :-(
Thanks
Peter
Procedure:
git clone https://github.com/epics-base/epics-base.git
cd epics-base/
git checkout -b 7.0.2
make
Error:
perl -CSD /usr/bin/xsubpp -typemap /usr/share/perl5/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -D_REENTRANT -D_GNU_SOURCE -O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -fexceptions -fstack-protector-strong -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fwrapv -fno-strict-aliasing -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/home/pgm/PROJECTS/EPICS7/epics-base/include/compiler/gcc -I/home/pgm/PROJECTS/EPICS7/epics-base/include/os/Linux -I/home/pgm/PROJECTS/EPICS7/epics-base/include -I/home/pgm/PROJECTS/EPICS7/epics-base/include/compiler/gcc -I/home/pgm/PROJECTS/EPICS7/epics-base/include/os/Linux -I/home/pgm/PROJECTS/EPICS7/epics-base/include -I/usr/lib64/perl5/CORE -MM -MF Cap5.d Cap5.c
cc1: error: ‘-fcf-protection=full’ requires Intel CET support. Use -mcet or both of -mibt and -mshstk options to enable CET
Fix:
diff --git a/modules/ca/src/perl/Makefile b/modules/ca/src/perl/Makefile
index 5b2bd5920..39917a6bd 100644
--- a/modules/ca/src/perl/Makefile
+++ b/modules/ca/src/perl/Makefile
@@ -54,7 +54,8 @@ endif
Cap5_SRCS = Cap5.xs
Cap5_LIBS = ca Com
Cap5_INCLUDES = -I$(shell $(PERL) ../perlConfig.pl archlib)/CORE
-Cap5_CFLAGS = $(shell $(PERL) ../perlConfig.pl ccflags)
+Cap5_CFLAGS =
Host system:
[pgm@hoy5 ~]$ cat /etc/redhat-release
Fedora release 28 (Twenty Eight)
[pgm@hoy5 ~]$ gcc -v
Using built-in specs.
gcc version 8.0.1 20180324 (Red Hat 8.0.1-0.20) (GCC)
https://epics.anl.gov seemed to be down the last couple days?. Nice to see it back up, thanks!
Peter Milne
Director of Sales
www.d-tacq.com
- Re: modules/ca/src/perl cc1: error: ‘-fcf-protection=full’ on first build of base Matt Newville via Tech-talk
- Re: modules/ca/src/perl cc1: error: ‘-fcf-protection=full’ on first build of base Johnson, Andrew N. via Tech-talk
Re: asynError in write on Power PMAC IOC Chanaka via Tech-talk
Re: asynError in write on Power PMAC IOC giles.knap--- via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
