An existing message stream is what is required by SteamDevice. It does
not launch the stream server in any means.
An aSub record would just work. In the subroutine you can launch the
script and parse its output.
If you are not fixed to database based IOC, a PCASpy server works
equally well. Here is an example close to what you are doing
https://pcaspy.readthedocs.io/en/latest/tutorial.html#example-2-interface-to-any-shell-command
Best
Xiaoqiang
On 1/14/19 9:25 AM, Bo Jakobsen via Tech-talk wrote:
Hi
I was considering to make a simple IOC to monitor our "queues" on a pc
cluster. The status of the queue can be returned from a simple shell script.
I was wondering if it is possible to use the streamDevice framework to
call a shell script on the IOC host and then process the output. That
would be a very easy way to make simple connections to existing programs.
What would be the best approach?
Best
Bo
- Re: Getting data from a shell script into an ioc Kasemir, Kay via Tech-talk
- Getting data from a shell script into an ioc Bo Jakobsen via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 14 Jan 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
