1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: How to use synApps optics module to control XIA pf4 filter
From: Zhibang Shen via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 16 Jan 2019 11:32:37 +0800 (GMT+08:00)
I am trying to use synApps optics module to control XIA pf4 filter. I have made the module and ran the code without error. SynApps xxx module could also be started to access to the PVs. However, pf4 filter did not work because I did not make any configuration about the ip address or serial port. I even didn't edit any code. I want to use local serial port to connect the host computer and pf4 filter. But I don't know how it works nor whether it works. I searched the startup script for hardware configure code like drvAsynIPPortConfigure or drvAsynSerialPortConfigure and I failed. So I would like someone to help me with the confusion.
Thanks a lot.
Zhibang Shen
Institute of High Energy Physics, Chinese Academy of Sciences
19B Yuquan Road, Shijingshan District, Beijing, China
100049
Prev: How to pick up value of environment variable in /configure/RELEASE? Michael Westfall via Tech-talk
Next: Fw: How to use synApps optics module to control XIA pf4 filter Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: How to pick up value of environment variable in /configure/RELEASE? Michael Westfall via Tech-talk
ANJ, 16 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
