1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: How can I get the severity fields values for a limit alarm?
From: bob dalesio via Tech-talk <[email protected]>
To: rperez <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 17 Jan 2019 06:00:51 -0800
In Channel Access, request get the DBR_CTRL_DBL. The menu is part of the metadata. Monitor the .VAL for alarm state changes  STAT and SEVR values are part of that metadata. In pvAccess, alarm strings are supported. Records and drivers are not yet taking advantage of that.
On Thu, Jan 17, 2019, 5:14 AM rperez via Tech-talk <[email protected] wrote:
Hello,
I am developing a CA client program in C and I need to handle the severity value for the alarm limits (HIHI, HIGH, LOW, LOLO). This is, the value of HHSV, HSV, LSV and LLSV fields.
To do this, I am executing the following code:
    struct dbr_ctrl_double    tPvData;
    double d
ata;
    chid    mychid;
    SEVCHK(ca_context_create(ca_disable_preemptive_callback),"ca_context_create");
    SEVCHK(ca_create_channel("PC:MEM_USED",NULL,NULL,10,&mychid),"ca_create_channel failure");
    SEVCHK(ca_pend_io(5.0),"ca_pend_io failure");
    SEVCHK(ca_get(DBR_DOUBLE,mychid,(void *)&tPvData),"ca_get failure");
     printf("PV Name %s :\n \talarm status: %d\n \talarm severity: %d\n \tvalue: %f\n \tunits: %s\n \talarm limits: [%d-%d]\n \twarning limits: [%d-%d]\n",
                               "PC:MEM_USED",  tPvData.status, tPvData.severity, tPvData.value, data.units,
                                tPvData.lower_alarm_limit, tPvData.upper_alarm_limit,
                                tPvData.lower_warning_limit, tPvData.upper_warning_limit);
    SEVCHK(ca_get(DBR_DOUBLE,mychid,(void *)&data),"ca_get failure");
    printf("
PV Name %s=%f\n","PC:MEM_USED", data);
    return(0);
As result I get the following PV's data, even the alarm (HIHI, LOLO) and warning (HI, LO) limits.
PV Name PC:MEM_USED  :
     alarm status: 3
     alarm severity: 2
     value: 100.000000
     units: %
     alarm limits: [nan-95.000000]
     warning limits: [nan-85.000000]
     PV Name PC:MEM_USED =100.000000
But to get the HHSV, HSV, LSV and LLSV fields, I am doing the following:
    SEVCHK(ca_create_channel("PC:MEM_USED.HHSV",NULL,NULL,10,&mychid),"ca_create_channel failure");
    printf("%s= %f\n","PC:MEM_USED.HHSV",data);
    SEVCHK(ca_create_channel("PC:MEM_USED.HSV",NULL,NULL,10,&mychid),"ca_create_channel failure");
    printf("%s= %f\n","PC:MEM_USED.HSV",data);
    SEVCHK(ca_create_channel("PC:MEM_USED.LLSV",NULL,NULL,10,&mychid),"ca_create_channel failure");
    printf("%s= %f\n","PC:MEM_USED.LLSV",data);
    SEVCHK(ca_create_channel("PC:MEM_USED.LSV",NULL,NULL,10,&mychid),"ca_create_channel failure");
    printf("%s=%f\n","PC:MEM_USED.LSV",data);
As result, I am getting this:
     "PC:MEM_USED.HHSV=2.000000" which means severity for a Hihi alarm is MAJOR
     "PC:MEM_USED.HSV=1.000000" which means severity for a Hi alarm is MINOR
     "PC:MEM_USED.LLSV=0.000000" which means severity for a Lolo alarm is NO_ALARM
     "PC:MEM_USED.LSV=0.000000" which means severity for a Lo alarm is NO_ALARM
Taking this into account, I have the following doubts:
  1. Is the value of the alarm severity  filed = 2 (MAJOR ) derived from this HHSV alarm severity limit field?  or is it only a coincidence that the value of the alarm severity is also 2 (MAJOR)? If so, what is the difference between the alarm severity field and the severity for a Hihi alarm field (HHSV)?
  2. Is this the correct way ( this is executing ca_get (PC:MEM_USED.HHSV), etc...) to obtain these HHSV, HSV, LLSV and LSV values?  Is there any other simpler way?
Thank you very much in advance.
Re: How can I get the severity fields values for a limit alarm? rperez via Tech-talk
Prev: File format for files in SynAps:calc module Jörn Dreyer via Tech-talk
Next: Re: How can I get the severity fields values for a limit alarm? Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: How can I get the severity fields values for a limit alarm? rperez via Tech-talk
Next: Re: How can I get the severity fields values for a limit alarm? rperez via Tech-talk
ANJ, 17 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
