1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: AreaDetector Code Not Updating
To: 'Iain Marcuson' <[email protected]>
Date: Mon, 21 Jan 2019 17:42:32 +0000
Hi Iain,
Ø  $(P)$(R)ArrayCounter_RBV does not update on taking an image, but there is no error reported for setIntegerParam(NDArrayCounter, imageCounter).  In addition, the NDArraySizeX and Y do not have the correct values.
Which $(P)$(R) are you referring to here?  I assume you mean the one for the NDStdArrays plugin?  That PV does not update when you call setIntegerParam(NDArrayCounter, imageCounter) in your driver.  There are separate PVs for NDArrayCounter in the driver and in each plugin.
The problem is probably that the NDStdArrays plugin is not being called.
That is most likely for one of the following reasons:
-       Your driver is not calling doCallbacksGenericPointer, perhaps because ArrayCallbacks is not enabled.
-       The NDStdArrays plugin is not enabled with the EnableCallbacks PV.
From: [email protected] <[email protected]> On Behalf Of Iain Marcuson via Tech-talk
Sent: Monday, January 21, 2019 11:34 AM
To: [email protected]
Subject: AreaDetector Code Not Updating
I am writing an AreaDetector driver for hardware we are building.  I am using EPICS Base 3.15.4, AreaDetector git commit f425743d3, and synApps 5.8, with asyn updated to 4-31.  I am basing my code off of code that works for another project, which is ultimately based off of the Mythen driver.  The driver I am writing receives data from the source, but it does not pass this information on via NDStdArrays.  $(P)$(R)ArrayCounter_RBV does not update on taking an image, but there is no error reported for setIntegerParam(NDArrayCounter, imageCounter).  In addition, the NDArraySizeX and Y do not have the correct values.  I can include the driver file if that would be helpful.
Thank you,
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com
Skype: [email protected]
RE: AreaDetector Code Not Updating Iain Marcuson via Tech-talk
Prev: AreaDetector Code Not Updating Iain Marcuson via Tech-talk
Next: RE: Problem in Stream Out of two 8 bit data Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: RE: AreaDetector Code Not Updating Iain Marcuson via Tech-talk
ANJ, 21 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
