1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Raspberry Pi 3 B+ Control System Studio
From: "Ivashkevych, Oksana via Tech-talk" <[email protected]>
To: Kevin Ramos <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Thu, 24 Jan 2019 17:20:20 +0000
Hi Kevin,
I have tried CSS on a more powerful platform UDOO x86. It has more CPU, memory, and most likely better video card.
  • First, you need to install X-windows on it. I got LightDM. Could be a bit of work.
  • Second, you can download executable from SNS controls.  Works like magic.
  • I would suggest trying new Phoebus, CSS is very much resource hungry.
In my case, I had a poor performance with any GUI application on X-windows including CSS when running directly from UDOO’s video card, most likely because the card is not good enough.  The poor performance is when you see how you drag your window in a slow motion.  However, when remotely connected, everything was fine, since I was using the Video card of another machine. You  can configure a bigger swap file/partition on Raspi, for example, to compensate for your possible memory problems, or, just install CSS/Phoebus on your laptop and connect to your RasPi via Ethernet. In the later case your Raspi will be just an EPICS server.
Good luck !
Oksana
> -----Original Message-----
> From: [email protected] <[email protected]> On
> Behalf Of Kevin Ramos via Tech-talk
> Sent: Wednesday, January 23, 2019 4:22 PM
> To: [email protected]
> Subject: Raspberry Pi 3 B+ Control System Studio
> Hello everyone!
> I have installed EPICS on raspberry pi 3 model B+, and I have successfully
> communicate with Arduino using Stream Device.
> Now, I am looking forward to use Control System Studio on rpi. It is possible to
> do it? How can I install it? Or do I have to use  linux, Mac or windows as an
> operating system on another platform?
> Thank you in advance.
> Best Regards,
> Kevin
Re: Raspberry Pi 3 B+ Control System Studio Kevin Ramos via Tech-talk
Prev: Re: EPICS still the king in 2019? Jeong Han Lee via Tech-talk
Next: Searching for Stream device db/proto for Lakeshore 331 temp controller Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Raspberry Pi 3 B+ Control System Studio Kevin Ramos via Tech-talk
Next: Re: Raspberry Pi 3 B+ Control System Studio Kevin Ramos via Tech-talk
ANJ, 24 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
