1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Changing record fields while PACT=1
From: Klemen Vodopivec via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 4 Feb 2019 10:03:22 -0500
for a new device support implementing IPMI bridge I'm exploring some design options. The easiest would be to kick-off asynchronous fetch when record starts processing and set PACT=1. When done, set PACT=0. In the mean time the asynchronous function would populate fields in the record. Because IPMI sensors have lots of metadata attached, fields like rec->hihi, rec->prec etc. would get populated as part of async operation.
Question is, is PACT=1 enough to ensure exclusive access to record fields? I know record won't process again but is there any EPICS db internals that will poke record while it's being processed?
Thanks, Klemen
Re: Changing record fields while PACT=1 Johnson, Andrew N. via Tech-talk
Prev: RE: Weird stream device behavior when using the IOC shell's exit function Mark Rivers via Tech-talk
Next: RE: AsynDriver with delayed and async communication Joao Afonso via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Weird stream device behavior when using the IOC shell's exit function Dirk Zimoch via Tech-talk
Next: Re: Changing record fields while PACT=1 Johnson, Andrew N. via Tech-talk
ANJ, 07 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
