1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Point Grey GigE Blackfly conflict
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: "'[email protected]'" <[email protected]>
Date: Thu, 7 Feb 2019 17:15:40 +0000
Hi Nilson,
What OS are you running Point Gray camera on? If it is Windows, then it is an intrinsic issue of the OS to run more than 1 camera, not related to network tuning, but Windows itself.
Kazimierz
Date: Thu, 7 Feb 2019 10:17:19 +0100
Subject: Point Grey GigE Blackfly conflict
Message-ID: <[email protected]">[email protected]>
Content-Type: text/plain; charset="utf-8"; format=flowed
Hello community,
I have 3 cameras (Point Grey GigE Blackfly) that I want to use
simultaneously at a very low framerate (1fps) for BPM purposes.
Each camera has its own IOC and they run perfectly one at a time.
However, when running simultaneously, always 2 cameras conflict with
each other and not necessary the same two cameras. During conflict, the
IOC shows an error about frame inconsistency on both affected cameras. I
have a gigabit network port on both switch and server, and the port is
far from saturation.
Does anyone have experience with GigE cameras and have seem this type of
problem? Is this a protocol issue since it happens even with the
original (Flycap2) software ?
I appreciate any shared experience with problems with GigE cameras that
could give a hint on why this is happening.
Best,
Nilson
Helmholtz-Zentrum Berlin f?r Materialien und Energie GmbH
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Gesch?ftsf?hrung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: Point Grey GigE Blackfly conflict Mark Rivers via Tech-talk
Re: Point Grey GigE Blackfly conflict Nilson Pereira via Tech-talk
Prev: Re: SPEC "can't get a big memory buffer" issue Heinz Junkes via Tech-talk
Next: RE: Point Grey GigE Blackfly conflict Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Point Grey GigE Blackfly conflict Mark Rivers via Tech-talk
ANJ, 08 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
