1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Stream device - parsing array of pairs of floats
From: Joao Afonso via Tech-talk <[email protected]>
Date: Thu, 14 Feb 2019 17:35:11 +0000
Hello,
I have a string returned by a device, representing an array where each element is a pair <time, value>:
- each pair is separated by "|": <timestamp>|<value>
- each element of the array separated by ","
- all values are floats
- the timestamp increment may not be linear (that is why it needs to be recorded)
Example
0.1000|0.1230000E+00,0.2000|0.4560000E+00,0.3000|0.7890000E+00, [...]
Is it possible to parse this using stream device (into two waveform records)?
Or do I have to use something more powerful such as asynDriver?
I have seen several examples, but only with using simple type elements, not like this.
As a followup, is it possible to do the inverse, merging two waveform records into a string?
Thank you in advance,
Joao
CERN TE-EPC-CCS
Re: Stream device - parsing array of pairs of floats Dirk Zimoch via Tech-talk
Re: Stream device - parsing array of pairs of floats Johnson, Andrew N. via Tech-talk
Prev: Re: How to detect AsynIPPort disconnect? Dirk Zimoch via Tech-talk
Next: RE: How to detect AsynIPPort disconnect? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Stream device - parsing array of pairs of floats Dirk Zimoch via Tech-talk
ANJ, 18 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
