1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: AreaDetector OCR plugin
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
Date: Fri, 15 Feb 2019 17:04:10 +0000
We have written an EPICS driver for  USB Video Class Cameras (UVC) which encompass most consumer webcams. We have tested it with several cameras ranging between 50 - 200 $
It is available here: https://github.com/epicsNSLS2-areaDetector
in the ADUVC repository. Also character recognition can probably be done in OpenCV w/ some form of machine learning, and we have been developing a Computer Vision plugin in the ADCompVision repository that could be a good start.
-Jakub Wlodek
All:
Has anyone developed an Optical Character Recognition plugin for
AreaDetector? The potential use case is to have a camera aimed at an
instrument front panel, and digitize the display to extract the
instrument's displayed output. I've already anticipated the potential
problems associated with multiplexed displays that may introduce
artifacts into the digitized images, so I don't want to attempt to
develop something that may be a failure anyway.
Are there any classes of inexpensive low resolution cameras supported by
AreaDetector? Like consumer grade webcams, for instance?
Yes, it's a hack, but easier than the alternatives in at least one
known case.
Rod Nussbaumer
TRIUMF
Vancouver, Canada
Prev: RE: How to detect AsynIPPort disconnect? Mark Rivers via Tech-talk
Next: RE: AreaDetector OCR plugin Heesterman, Peter J via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: AreaDetector OCR plugin Michael Davidsaver via Tech-talk
Next: EPICS June 2019: Sponsoring Opportunities Ralph Lange via Tech-talk
ANJ, 15 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
