1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Can I configure CA Gateway to ignore boardcast
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 25 Feb 2019 17:24:01 +0100
Hi Phil,
I would not expect this to be possible in the scope of the Gateway configuration.
Of course, if your Gateway is running on a host of its own, you could set up firewall rules to achieve this.
Another idea: since you will have to configure the clients anyway (to make them use unicasts for name resolution), why don't you run your Gateway on a different server side port instead? The clients will understand the usual "machine.net:port" notation.
Cheers,
~Ralph
On Mon, 25 Feb 2019 at 16:47, Phillip A. Sorensen via Tech-talk <[email protected]> wrote:
Good Morning,
I am setting up an EPICS CA gateway between to networks, but I would
like the gateway to only respond to direct name searches and not to
broadcast name searches.  Is this even possible with the current gateway
or CA protocol?
I tried setting the -signore to the broadcast address but that did not work.
Phil Sorensen
Can I configure CA Gateway to ignore boardcast Phillip A. Sorensen via Tech-talk
Prev: Can I configure CA Gateway to ignore boardcast Phillip A. Sorensen via Tech-talk
Next: Re: EPICS Base compile failure on Windows-x64 Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Can I configure CA Gateway to ignore boardcast Smith, Martin via Tech-talk
ANJ, 26 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
