1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: generalTime/epicsTimeGetCurrent and casr questions
To: "'Brands Helge (PSI)'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 12 Mar 2019 19:15:21 +0000
Hi Helge,
Thanks.  So it appears that for every Channel Access write operation in caQtDM a new channel is created and then destroyed by this code?
int EpicsSetValue(char *pv, double rdata, int32_t idata, char *sdata, char *object, char *errmess, int forceType)
    chid     ch;
    chtype   chType;
    int status;
    struct dbr_ctrl_double ctrlR;
    struct dbr_sts_string ctrlS;
    UNUSED(errmess);
    UNUSED(object);
    if(strlen(pv) < 1)  {
            C_postMsgEvent(messageWindowPtr, 1, vaPrintf("pv with length=0 (not translated for macro?)\n"));
            return !ECA_NORMAL;
    PrepareDeviceIO();
    // set epics value
    PRINT(printf(" we have to set a value to an epics device <%s> %f %ld <%s>\n", pv, rdata, idata, sdata));
    status = ca_create_channel(pv, NULL, 0, CA_PRIORITY, &ch);
    if (ch == (chid) 0) {
        return !ECA_NORMAL;
    status = ca_pend_io(CA_TIMEOUT);
    status = ca_clear_channel(ch);
    return ECA_NORMAL;
When I move a slider this can be happening many times per second.  Is this the way other display managers work?  I wonder why it does not call ca_create_channel just once and re-use the chid?
-----Original Message-----
Sent: Tuesday, March 12, 2019 3:57 AM
Cc: 'Johnson, Andrew N.' <[email protected]>; 'Johnson, Andrew N.' <[email protected]>; '[email protected]' <[email protected]>
Subject: AW: generalTime/epicsTimeGetCurrent and casr questions
The problem you are talking about was fixes in the commit (ab2fe66) clear epics channel after writing 2.5.18 by Anton This is in Version 4.2.1 the first line:  "after write epics channel is cleared now"
Best regards
                Helge
-----Ursprüngliche Nachricht-----
Von: Mark Rivers [mailto:[email protected]]
Gesendet: Montag, 11. März 2019 16:29
An: 'Johnson, Andrew N.'
Cc: 'Layne (US), William C'; '[email protected]'; Brands Helge (PSI)
Betreff: RE: generalTime/epicsTimeGetCurrent and casr questions
Matt Newville and I tested the apparent problem with caQtDM this morning.
We were running version 4.1.7.  We found that the problem was with the slider widget.  Each time the slider was moved it opened dozens of new connections reported with casr on the IOC.
We updated to the latest release, 4.2.1 and the problem went away.
I don't see this issue mentioned in the caQtDM release notes. https://github.com/caqtdm/caqtdm/releases
Sent: Saturday, March 9, 2019 6:16 PM
To: 'Johnson, Andrew N.' <[email protected]>
Cc: Layne (US), William C <[email protected]>; [email protected]
Hi Andrew,
I realized something must be wrong.  Ferrari is a Windows workstation that Matt Newville uses for our microprobe.  I asked Matt what could be connecting to those PVs, and he thought it must be caQtDM windows.  He restarted caQtDM and indeed over 4000 connections, to just a few dozen PVs, went away on the IOC.  Now casr 2 reports this for that client on Ferrari:
    TCP client at 164.54.160.93:60618 'Ferrari':
        User 'XAS_User', V4.13, Priority = 0, 21 Channels
        Channel: '13IDA:eps_mbbi195'
        Channel: '13IDA:eps_mbbi192'
        Channel: '13IDA:eps_mbbi194'
        Channel: '13IDA:OpenEShutter.PROC'
        Channel: '13IDA:CloseEShutter.PROC'
        Channel: '13IDA:eps_mbbi27'
        Channel: '13IDA:IDEAutoOpenMode'
        Channel: '13IDA:DAC1_7_tweak.A'
        Channel: '13IDA:DAC1_7_tweak.B'
        Channel: '13IDA:DAC1_7_tweakVal'
        Channel: '13IDA:DAC1_7.VAL'
        Channel: '13IDA:DAC1_8_tweak.A'
        Channel: '13IDA:DAC1_8_tweak.B'
        Channel: '13IDA:DAC1_8_tweakVal'
        Channel: '13IDA:DAC1_8.VAL'
        Channel: '13IDA:E_BPMFoilPosition_RBV'
So now there are 2 instances of DAC1_7.VAL and DAC1_8.VAL, while before restarting caQtDM there were hundreds of instances of each.
So the problem definitely appears to be caQtDM.  On Monday when there is no beam we will try opening and closing the caQtDM window to those PVs repeatedly to see if the number of connections keeps increasing.  If it does we will check to make sure we are using the latest release of caQtDM, and report a bug if the latest release also has the problem.
Sent: Saturday, March 9, 2019 4:18 PM
Subject: Re: generalTime/epicsTimeGetCurrent and casr questions
Hi Mark,
Your client running on Ferrari is definitely not coded properly, it looks like it is continually creating a new chid instead of re-using an existing one for that channel. This will be using up memory on both the IOC and the client (until the client restarts, which will then release the IOC resources), so I strongly recommend that you find out what it is and fix it.
William — regarding your question about generalTime, I believe Michael Davidsaver has some ideas about rewriting the generalTime code to try and reduce the contentions on that mutex (it’s probably the one you named but I don’t have the code in front of me to check right now). I don’t know how far he has got with that if anywhere though.
- Andrew
Sent from my iPad
> On Mar 9, 2019, at 10:31 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
> Hi William,
>   I am noticing that in some of our ‘casr’ outputs, we are seeing multiple TCP connections with the same PV channel connected. Is this normal behavior?
> a.       For some reason, I assumed Channel Access wouldn’t allow this. If it is normal behavior, any suggestions on ways to prevent it? (I know having the users checking would be a good way J)
> I am not sure what you mean by "multiple TCP connections with the same PV channel connected"?  Do you mean from the same host?  Do they have different port numbers, like this?
>    TCP client at 164.54.160.82:41108 'corvette':
>        User 'epics', V4.13, Priority = 80, 108 Channels
>        Channel: '13IDA:scan1.P1SP'
>        Channel: '13IDA:scan1.P1EP'
>        Channel: '13IDA:scan1.NPTS'
>        Channel: '13IDA:scan1.EXSC'
>        Channel: '13IDA:scan1.MPTS'
>        Channel: '13IDA:scan1.BUSY'
>        Channel: '13IDA:scan1.CMND'
>        Channel: '13IDA:scan1.P1SM'
>    TCP client at 164.54.160.82:41110 'corvette':
>        User 'epics', V4.13, Priority = 80, 129 Channels
> If so those are just 2 different clients on the same host connecting to the same PV.  That is normal.
> On the other hand I am also seeing things like this, which I am not sure is normal:
>    TCP client at 164.54.160.93:60193 'Ferrari':
>        User 'XAS_User', V4.13, Priority = 50, 4249 Channels
> Mark
> ________________________________
> From: [email protected] <[email protected]> on
> behalf of Layne (US), William C via Tech-talk <[email protected]>
> Sent: Friday, March 8, 2019 6:18 PM
> To: [email protected]
> Subject: generalTime/epicsTimeGetCurrent and casr questions
> Hello, haven’t posted here before so here it goes. (Recently completed
> some training and was encouraged to reach out more)
> I figure I will start with some of the more softball questions as we are seeing various issues here:
> 1.       Has anyone seen issues with multiple threads using the generalTime subsystem?
> a.       We are having some performance issues with a large number of clients (>100) and am trying to narrow down which futex we are spending lots of time in. I will run some tests later this week to see if the ‘timeListLock’ could be impacting them.
> 2.       I am noticing that in some of our ‘casr’ outputs, we are seeing multiple TCP connections with the same PV channel connected. Is this normal behavior?
> a.       For some reason, I assumed Channel Access wouldn’t allow this. If it is normal behavior, any suggestions on ways to prevent it? (I know having the users checking would be a good way :))
> Hope to be participating more. Thanks,
> William ‘Casey’ Layne
> Stage Controller – Software Engineer
> Email: [email protected]<mailto:[email protected]>
> Any opinions expressed herein are my own.  They are not necessarily those of Boeing, or any other company or organization with which I am affiliated.
AW: generalTime/epicsTimeGetCurrent and casr questions Brands Helge (PSI) via Tech-talk
generalTime/epicsTimeGetCurrent and casr questions Layne (US), William C via Tech-talk
Re: generalTime/epicsTimeGetCurrent and casr questions Mark Rivers via Tech-talk
Re: generalTime/epicsTimeGetCurrent and casr questions Johnson, Andrew N. via Tech-talk
RE: generalTime/epicsTimeGetCurrent and casr questions Mark Rivers via Tech-talk
Prev: RE: ADPIcam driver question Mark Rivers via Tech-talk
Next: RE: areaDetector training at the EPICS Collaboration Meeting Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: AW: generalTime/epicsTimeGetCurrent and casr questions Brands Helge (PSI) via Tech-talk
Next: AW: generalTime/epicsTimeGetCurrent and casr questions Brands Helge (PSI) via Tech-talk
ANJ, 13 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
