Tim Mooney ( [email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Wednesday, March 13, 2019 4:49 PM
To: Daniel Cuneo
Subject: Re: Count record that resets by date
There's certainly a way to do this with base, but on an APS beamline, I would do it like this:
devIocStats maintains a time-of-day string PV, here called xxx:TOD, which updates every second. When the _expression_ xxx:TOD=="00:00:00" changes value, the string calc writes that value to the calcout record's B field,
and causes it to process. This sets the calcout record's VAL field to -1 when TOD=="00:00:00", and then to 0 when TOD=="00:00:01". Otherwise, the calcout record's VAL field increments whenever it's processed.
Hi all,
I'd like to create a database record that counts based on a forward link. This record would need to reset back to zero
at 12AM every day.
Use case, is where a beam line user hits a reset button repeatably (tied to a bo record) as a work around for something that is broken.
I'd like to track these resets.
Is there a way to do this with base?
I'm considering writing a C subroutine for this is it doesn't already exist.
Cheers!
dpc
Description: count_reset.jpg
- Count record that resets by date Daniel Cuneo via Tech-talk
Re: Count record that resets by date Daniel Cuneo via Tech-talk
Re: Count record that resets by date Eric Norum via Tech-talk
<2019>
2025
2026
Re: Count record that resets by date Diego Omitto via Tech-talk
<2019>
2025
2026
ANJ, 13 Mar 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
