1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Count record that resets by date
From: Daniel Cuneo via Tech-talk <[email protected]>
To: Eric Norum <[email protected]>
Date: Wed, 13 Mar 2019 18:59:30 -0400
Thanks everyone, I've got enough to chew on now.
On Wed, Mar 13, 2019 at 3:12 PM Eric Norum <[email protected]> wrote:
Here’s an all-database solution that does what you want, I think.  I’m no expert on databases, so there may very well be ways of doing this with fewer records.
The ‘count’ record increments each time it’s processed unless the ‘clear’ record has pushed a 1 into the ‘C’ field.
record(bi, "$(user):now") {
    field(PINI, "YES")
    field(SCAN, "10 second")
    field(FLNK, "$(user):day")
record(stringin, "$(user):day") {
    field(DTYP, "Soft Timestamp")
    field(INP,  "@%j")
    field(TSEL, "$(user):now.TIME")
    field(FLNK, "$(user):clear")
record(calcout, "$(user):clear") {
    field(INPA, "$(user):day NPP MS")
    field(INPB, "1000")
    field(CALC, "A<B;B:=A")
    field(OOPT, "When Non-zero")
    field(OCAL, "1")
    field(OUT,  "$(user):count.C PP")
record(calc, "$(user):count") {
    field(VAL,  "0")
    field(TPRO, 1)
    field(CALC, "C?0:VAL+1;C:=0")
On Mar 13, 2019, at 2:07 PM, Daniel Cuneo via Tech-talk <[email protected]> wrote:
Hi all,
I'd like to create a database record that counts based on a forward link. This record would need to reset back to zero
at 12AM every day.
Use case, is where a beam line user hits a reset button repeatably (tied to a bo record) as a work around for something that is broken.
I'd like to track these resets.
Is there a way to do this with base?
I'm considering writing a C subroutine for this is it doesn't already exist.
Cheers!
dpc
Count record that resets by date Daniel Cuneo via Tech-talk
Re: Count record that resets by date Eric Norum via Tech-talk
Prev: Re: Count record that resets by date Eric Norum via Tech-talk
Next: Re: Count record that resets by date Diego Omitto via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Count record that resets by date Matt Newville via Tech-talk
ANJ, 14 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
