1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice processing issue
From: "Lucock, Richard M via Tech-talk" <[email protected]>
To: "Davis, Mark" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 18 Mar 2019 08:57:51 +0000
I am working on a StreamDevice interface for an Edwards STP turbomolecular pump and am having a problem with processing of one of the longer replies.
The problem appears to be that the ability to match a sequence of bytes for the "in" command when the bytes span multiple packets does not work for protocols that do not start with an "out" command (i.e. those linked to "I/O Intr" records).
  Is this the SCU1600 controller ? We have a number of them running. I
did have a problem with the controller occasionally delaying parts of
the longer responses (resulting in packet splitting) but I found that
a ReadTimeout of 150ms did the trick for us (100ms was just on the
edge). Other than that, I've had no problems using the controller.
Cheers,
       Richard
| UK ATOMIC
| ENERGY
| AUTHORITY
Dr. Richard Lucock
Software control engineer
United Kingdom Atomic Energy Authority
Culham Science Centre, Abingdon, OX14 3DB, UK
Tel. +44 (0)1235 464713
Email: [email protected]
The content of this email is confidential and intended for the recipient specified in the message only. It is forbidden to share any part of this message with any third party, without the written consent of the sender. If you received this message by mistake, please reply to this message and then delete it, so that we can ensure it does not occur in the future.
Re: StreamDevice processing issue Davis, Mark via Tech-talk
Prev: [no subject] VASU PADSUMBIA via Tech-talk
Next: Re: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED] Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice processing issue Davis, Mark via Tech-talk
Next: Re: StreamDevice processing issue Davis, Mark via Tech-talk
ANJ, 19 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
