1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED]
To: "'CORNALL, Terry'" <[email protected]>
Cc: "'SAMARDZIC-BOBAN, Vesna'" <[email protected]>, 'Andrew Price' <[email protected]>, "'CLIFT, Mark'" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Mon, 18 Mar 2019 20:06:35 +0000
I realized that there is no requirement that the “port” and “localPort” in the drvAsynIPPortConfigure command be the same.  “port” is the port that asyn will send broadcast messages on, localPort is the port that it will listen for broadcast messages on.
I just tried this, the send port is is 3957, the receive port is 3956.  It should listen for broadcast messages on port 3956 and send 3 broadcast messages on port 3957.
drvAsynIPPortConfigure("BD","255.255.255.255:3957:3956 UDP*",0,0,0)
asynSetTraceIOMask("BD", 0, 2)
asynSetTraceMask("BD", 0, 9)
iocInit
asynOctetConnect BD1 BD 0 10  200  #address 0, timeout of 10 sec, buffer 200
asynOctetRead BD1 100
asynOctetWrite BD1 "test1"
asynOctetWrite BD1 "test2"
asynOctetWrite BD1 "test3"
This is the output:
2019-03-18T14:43:49.044 Using dynamically assigned TCP port 53809.
2019/03/18 14:43:49.045 255.255.255.255:3957:3956 UDP* (from 164.54.160.93:4311) read 8
\300\177\363\000\000\000\000\004
2019/03/18 14:43:49.045 255.255.255.255:3957:3956 UDP* (from 164.54.160.118:54121) read 8
B\021\000\002\000\000)\266
2019/03/18 14:43:49.045 255.255.255.255:3957:3956 UDP* (from 164.54.160.173:59185) read 8
B\021\000\002\000\000_\377
2019/03/18 14:43:49.046 255.255.255.255:3957:3956 UDP* (from 164.54.160.150:4311) read 8
B\021\000\002\000\000\000\001
2019/03/18 14:43:49.136 255.255.255.255:3957:3956 UDP* (from 164.54.160.150:4311) read 8
2019/03/18 14:43:49.340 255.255.255.255:3957:3956 UDP* (from 164.54.160.162:62189) read 8
B\021\000\002\000\000\334\372
2019/03/18 14:43:49.385 255.255.255.255:3957:3956 UDP* (from 164.54.160.93:4310) read 8
2019/03/18 14:43:49.510 255.255.255.255:3957:3956 UDP* (from 164.54.160.93:4310) read 8
2019/03/18 14:43:49.535 255.255.255.255:3957:3956 UDP* (from 164.54.160.173:52160) read 8
2019/03/18 14:43:49.681 255.255.255.255:3957:3956 UDP* (from 164.54.160.118:54121) read 8
B\021\000\002\000\000)\267
2019/03/18 14:43:49.944 255.255.255.255:3957:3956 UDP* (from 164.54.160.47:63488) read 8
2019/03/18 14:43:49.994 255.255.255.255:3957:3956 UDP* (from 164.54.160.150:4310) read 8
2019/03/18 14:43:50.119 255.255.255.255:3957:3956 UDP* (from 164.54.160.150:4310) read 8
eomReason 0x1
\300\177\363\000\000\000\000\004B\021\000\002\000\000)\266B\021\000\002\000\000_\377B\021\000\002\000\000\000\001\300\177\363\000\000\000\000\004B\021\000\002\000\000\334\372B\021\000\002\000\000\000\001\300\177\363\000\000\000\000\004B\021\000\002\000\000_\377B\021\000\002\000\000)\267B\021\000\002\000\000_\377B\021\000\002\000\000\000\001\300\177\363\000
2019/03/18 14:43:50.120 255.255.255.255:3957:3956 UDP* write 5
test1
test2
test3
epics>
This is part of the capture from tcpdump.
This is the packet received from 164.54.160.118 at 14:43:49.681 reported above.  This proves it is listening on port 3956 correctly.
14:43:49.681290 IP viper.cars.aps.anl.gov.54121 > 255.255.255.255.gvcp: UDP, length 8
     0x0000:  4500 0024 069b 4000 4011 ef81 a436 a076  E..$..@[email protected]
     0x0010:  ffff ffff d369 0f74 0010 6c79 4211 0002  .....i.t..lyB...
     0x0020:  0000 29b7 0000 0000 0000 0000 0000       ..)...........
These are the 3 broadcast messages that asyn sent on port 3957, which is the officially registered port for the mqe-broker.  The message contents are test1, test2, test3 as expected.
14:43:50.119680 IP corvette.cars.aps.anl.gov.gvcp > 255.255.255.255.mqe-broker: UDP, length 5
     0x0000:  4500 0021 f2b2 4000 4011 0391 a436 a052  E..!..@[email protected]
     0x0010:  ffff ffff 0f74 0f75 000d 44a7 7465 7374  .....t.u..D.test
     0x0020:  31                                       1
14:43:50.120012 IP corvette.cars.aps.anl.gov.gvcp > 255.255.255.255.mqe-broker: UDP, length 5
     0x0000:  4500 0021 f2b3 4000 4011 0390 a436 a052  E..!..@[email protected]
     0x0020:  32                                       2
14:43:50.120307 IP corvette.cars.aps.anl.gov.gvcp > 255.255.255.255.mqe-broker: UDP, length 5
     0x0000:  4500 0021 f2b4 4000 4011 038f a436 a052  E..!..@[email protected]
     0x0020:  33                                       3
I will update the asyn documentation to note that “port” and “localport” can be different for UDP broadcasts,
Sent: Monday, March 18, 2019 8:48 AM
To: CORNALL, Terry <[email protected]>
Cc: SAMARDZIC-BOBAN, Vesna <[email protected]>; Andrew Price <[email protected]>; CLIFT, Mark <[email protected]>; [email protected]
Hi Terry,
I just verified that my suggestion works.  This is from my startup script:
drvAsynIPPortConfigure("BD","255.255.255.255:3956:3956 UDP",0,0,0)
iocInit
So I am listening for broadcasts on port 3956, which is the GigeVision Control Port (gvcp).
When I run the IOC I see the following:
iocInit
Starting iocInit
## EPICS R7.0.2
## EPICS Base built Dec 21 2018
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 40596,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2019-03-18T08:38:32.152 Using dynamically assigned TCP port 50457.
2019/03/18 08:38:32.153 255.255.255.255:3956:3956 UDP (from 164.54.160.118:54121) read 8
B\021\000\002\000\000\324\030
2019/03/18 08:38:32.153 255.255.255.255:3956:3956 UDP (from 164.54.160.15:59139) read 8
2019/03/18 08:38:32.269 255.255.255.255:3956:3956 UDP (from 164.54.160.162:62189) read 8
B\021\000\002\000\000\207]
2019/03/18 08:38:32.376 255.255.255.255:3956:3956 UDP (from 164.54.160.150:4311) read 8
2019/03/18 08:38:32.493 255.255.255.255:3956:3956 UDP (from 164.54.160.93:4310) read 8
2019/03/18 08:38:32.501 255.255.255.255:3956:3956 UDP (from 164.54.160.150:4311) read 8
2019/03/18 08:38:32.617 255.255.255.255:3956:3956 UDP (from 164.54.160.93:4310) read 8
2019/03/18 08:38:32.681 255.255.255.255:3956:3956 UDP (from 164.54.160.118:54121) read 8
B\021\000\002\000\000\324\031
2019/03/18 08:38:32.708 255.255.255.255:3956:3956 UDP (from 164.54.160.47:63488) read 8
2019/03/18 08:38:33.273 255.255.255.255:3956:3956 UDP (from 164.54.160.162:62189) read 8
B\021\000\002\000\000\207^
2019/03/18 08:38:33.343 255.255.255.255:3956:3956 UDP (from 164.54.160.150:4310) read 8
2019/03/18 08:38:33.442 255.255.255.255:3956:3956 UDP (from 164.54.160.173:52160) read 8
2019/03/18 08:38:33.460 255.255.255.255:3956:3956 UDP (from 164.54.160.93:4311) read 8
eomReason 0x1
B\021\000\002\000\000\324\030B\021\000\002\000\000_\377B\021\000\002\000\000\207]B\021\000\002\000\000\000\001B\021\000\002\000\000\000\001\300\177\363\000\000\000\000\004\300\177\363\000\000\000\000\004B\021\000\002\000\000\324\031B\021\000\002\000\000_\377B\021\000\002\000\000\207^B\021\000\002\000\000\000\001B\021\000\002\000\000_\377B\021\000\002
So I am correctly seeing the broadcast messages from a number of machines on that port.
I reproduced your result that it does not work if I omit the localPort parameter in the drvAsynIPPort command.
I verified that it works with either UDP or UDP* in the drvAsynIPPort configure command.
I will update the documentation to say that the localPort parameter is required to receive UDP broadcasts.
Sent: Monday, March 18, 2019 7:14 AM
Subject: Re: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED]
Hi Terry,
I just looked at the code for drvAsynIPPort.  It only calls bind() if you specify the localPort in your hostInfo string.  So I think this should be
drvAsynIPPortConfigure("CRYOREAD01","255.255.255.255:30304:30304 UDP*",0,0,0)
I think you maybe should use UPD and not UDP*.  UDP* is meant for sending broadcasts, not receiving them.
I am not sure anyone has used drvAsynIPPort for receiving broadcasts, only for sending them.  Please give the above a try and if it does not work I will fix the driver.
From: [email protected] <[email protected]> on behalf of CORNALL, Terry via Tech-talk <[email protected]>
Sent: Sunday, March 17, 2019 11:31 PM
To: [email protected]
Cc: SAMARDZIC-BOBAN, Vesna; Andrew Price; CLIFT, Mark
Subject: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED]
Hi All.
I have a device that sends its status as a UDP broadcast with port 30304 and I’d like to use asynIP to get it but can’t get it working using simple interactive commands in EPICS iocsh.
I have successfully tested the server and host in question  using a little python socket program, essentially:
########### start PYTHON CODE###############
broadcastIP = '255.255.255.255'   #note that 10.6.255.255 doesn’t work, though I expected it to…
idBroadcast = (broadcastIP,30304)
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM, socket.IPPROTO_UDP)
s.bind(idBroadcast)
m, reportedAddress = s.recvfrom(bufMax)  #m gets the data and reportedAddress indicates where it was broadcast from
################END PYTHON CODE######################
and it works, gets the status every second. So no firewalls getting in the way and the port number is OK and status is being broadcast every second as expected.
Trying to use asynIP in EPICS, I do the following to test, using asynDriver release 4.34:
#########start EPICS IOCSH commands############
drvAsynIPPortConfigure("CRYOREAD01","255.255.255.255:30304 UDP*",0,0,0)  #Have also tried the specific subnet broadcast 10.6.0.255 and 10.6.255.255 with no luck
…… #no errors reported
iocInit()
asynSetTraceMask  ("CRYOREAD01",-1,0xFF)
asynSetTraceIOMask("CRYOREAD01",-1,0xFF)
…..#no errors reported
epics>
#Then ran the following interactively
epics> asynOctetConnect CR CRYOREAD01 0 10  200  #address 0, timeout of 10 sec, buffer 200
epics> asynOctetRead CR 100
From asynTrace I get:
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPort locking port
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPort created queueLockPortPvt=0x183c0f0
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPort created queueLockPortPvt=0x183c0f0, event=0x183c110, mutex=0x18318c0
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPort taking mutex 0x18318c0
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPort queueing request
2019/03/18 15:10:17.359 CRYOREAD01 addr -1 queueRequest priority 0 not lockHolder
2019/03/18 15:10:17.359 CRYOREAD01 schedule queueRequest timeout
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPort waiting for event
2019/03/18 15:10:17.359 asynManager::portThread port=CRYOREAD01 callback
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPortCallback signaling begin event
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2019/03/18 15:10:17.359 CRYOREAD01 asynManager::queueLockPort got event from callback
2019/03/18 15:10:17.359 255.255.255.255:30304 UDP* read.
…..waits 10 sec
2019/03/18 15:10:27.369 CRYOREAD01 read from low-level driver returned 1
2019/03/18 15:10:27.369 CRYOREAD01 queueUnlockPort
2019/03/18 15:10:27.369 CRYOREAD01 asynManager::queueUnlockPort waiting for event
2019/03/18 15:10:27.369 CRYOREAD01 queueUnlockPort unlock mutex 0x18318c0 complete.
2019/03/18 15:10:27.369 Error reading, ninp=0 error 255.255.255.255:30304 UDP* timeout: Resource temporarily unavailable
and it always timesout with nothing received.
I also tried asynReport 4 CRYOREAD01 and got the following. Somewhat suspicious of nDevices=0 but this might be ok for a nonMultiDevice?
CRYOREAD01 multiDevice:No canBlock:Yes autoConnect:Yes
    enabled:Yes connected:Yes numberConnects 1
    nDevices 0 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 1 exceptionNotifys 0
    traceMask:0xff traceIOMask:0xff traceInfoMask:0x1
    interposeInterfaceList
        asynOctet pinterface 0x7f986797d6e0 drvPvt 0x16d1410
    interfaceList
        asynCommon pinterface 0x7f986797a750 drvPvt 0x16cd7c0
        asynOption pinterface 0x7f986797a770 drvPvt 0x16cd7c0
        asynOctet pinterface 0x16cd8e0 drvPvt 0x16cd7c0
    Port 255.255.255.255:30304 UDP*: Connected
                    fd: 4
    Characters written: 0
       Characters read: 0
Can anyone suggest why this isn’t working or what I should do to better test it? (I did see comment in techtalk about UDP broadcast issues, but I think they were for versions older than the one I am using)
Terry
RE: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
Re: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED] Mark Rivers via Tech-talk
RE: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED] Mark Rivers via Tech-talk
Prev: Re: Inter-module dependency between stream and calc Ralph Lange via Tech-talk
Next: RE: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: drvAsynIPPort Not receiving broadcast UDP [SEC=UNCLASSIFIED] Mark Rivers via Tech-talk
ANJ, 18 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
