1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Fwd: pvget is timing out
Date: Sat, 23 Mar 2019 14:47:35 +0000
Forgot to cc tech-talk
Sent from my iPhone
Begin forwarded message:
From: Mark Rivers <[email protected]<mailto:[email protected]>>
Date: March 23, 2019 at 9:30:17 AM CDT
To: "Ivashkevych, Oksana" <[email protected]<mailto:[email protected]>>
Subject: Re: pvget is timing out
Do
pvget -h
to get help.
pvget defaults to using pvAccess protocol. That can only read normal IOC pvs if your IOC is running qsrv or equivalent.
To use pvget to use Channel Access do
pvget -p ca pvname
Example:
corvette:~>pvget -p ca 13IDA:m1
13IDA:m1 -0.25
Sent from my iPhone
On Mar 23, 2019, at 8:31 AM, Ivashkevych, Oksana via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hello,
I have built latest epics-base branch 7.0 and R.7.0.2.1 on Windows 7 and CentOS 4.4.7.(tested both).  I cloned with - - recursive option. When I am using caget(), it works, pvget() doesn't. It doesn't even print me an error message when I don't specify a PV. Behaves identical on both systems. When I specify a PV, request times out.
On this CentOS system I have only base built and nothing running
det@xf11bm-pilatus800k:~/epics/epics-base/bin/linux-x86_64> ./caget
No pv name specified. ('caget -h' for help.)
det@xf11bm-pilatus800k:~/epics/epics-base/bin/linux-x86_64> ./pvget
On this Windows 7 I have bunch of modules built and my new driver and IOC, which theoretically could be a contributing factor, but I don't think so.
C:\epics\epics-base>bin\windows-x64-static\pvget.exe
//prints empty line
C:\epics\epics-base>bin\windows-x64-static\caget.exe
C:\epics\epics-base>git branch
* (HEAD detached at R7.0.2.1)
  7.0
C:\epics\epics-base\bin\windows-x64-static>caget XF11ID-ES{elveFlowOB1}:elveFlow:Pres1
XF11ID-ES{elveFlowOB1}:elveFlow:Pres1 22.3389
C:\epics\epics-base\bin\windows-x64-static>pvget XF11ID-ES{elveFlowOB1}:elveFlow:Pres1
Timeout
I have another system with Debian 7.
On this Debian 7 I have bunch of ADProsilica  and ADPilatus iocs running, built with base 7.0.1. At least pvget() responds with the correct complaint, though  times out with a PV.
oksana@xf11bm-ioc1:/epics/distrib/epicsBundle-R-7-0-1+deb7u1-x86_64/epics-base/bin/linux-x86_64$ ./pvget
No pv name(s) specified. ('pvget -h' for help.)
oksana@xf11bm-ioc1:/epics/distrib/epicsBundle-R-7-0-1+deb7u1-x86_64/epics-base/bin/linux-x86_64$ ./pvget XF:11BMA-BI{FS:1-Cam:1}cam1:AcquireTime
Timeout
oksana@xf11bm-ioc1:/epics/distrib/epicsBundle-R-7-0-1+deb7u1-x86_64/epics-base/bin/linux-x86_64$ ./caget XF:11BMA-BI{FS:1-Cam:1}cam1:AcquireTime
XF:11BMA-BI{FS:1-Cam:1}cam1:AcquireTime 1
There is one system where pvget() does work. One year ago I built from core/master on Debian 8. This branch is closed now.  On this machine I have one ADprosilica and one ADPointGrey IOC running with this base. There are other IOCs, but they use Debian distribution.
oksana@xf11id-m1:/opt/epics/ADepics7/epics-base/bin/linux-x86_64$ ./pvget XF:MOBILE-BI{Mir:1}cam1:AcquireTime
XF:MOBILE-BI{Mir:1}cam1:AcquireTime 0.3
oksana@xf11id-m1:/opt/epics/ADepics7/epics-base/bin/linux-x86_64$ ./caget XF:MOBILE-BI{Mir:1}cam1:AcquireTime
oksana@xf11id-m1:/opt/epics/ADepics7/epics-base/bin/linux-x86_64$ git branch
* core/master
What I could be missing? Why pvget() does not work for me?
Oksana
pvget is timing out Ivashkevych, Oksana via Tech-talk
Prev: pvget is timing out Ivashkevych, Oksana via Tech-talk
Next: Re: pvget is timing out Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 23 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
