1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Nested PVStructureArray With pvput
From: William Cork via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: [email protected]
Date: Tue, 2 Apr 2019 22:37:16 -0700
The end-goal is to give clients control of services from a window using Phoebus in new projects.
There shouldn't be any race conditions from multiple clients as service interaction will come from either the system running Monit or interaction with the PVAServer that handles the transactions.
RPC (learning about it with EPICS/Phoebus now) may be a better use case for this while pvAccess can provide the current states. This will also simplify the pv structure.
I'll keep digging.
Thanks Michael,
Will
On Tue, Apr 2, 2019 at 9:38 PM Michael Davidsaver <[email protected]> wrote:
On 4/2/19 8:23 PM, William Cork via Tech-talk wrote:
> Hi All,
> I’m working on a softIOC that will make calls to a Monit daemon to restart and monitor services under Monit.
> Right now, I have the following pv structure (a wip):
> |test:Monit:localhost structure string host http://localhost:2812 int poll 120 structure[] services structure string name testService boolean monitored true int state 0 string type SERVICE epics:nt/NTEnum:1.0 action enum_t value int index 0 string[] choices ["none", "enable", "disable", "start", "stop", "restart"] |
> Is it possible to change an element in the nested services list with pvput, or are the immutable?
> |pvput test:Monit:localhost services='...'| may be the wrong syntax?
> More precisely, can I change services[index of service I care about].action = "" of the action enums.
> Architecturally speaking, is it more ideal to have a bookkeeping PVArray that lists the provided services and individual PVs for each service?
Are you thinking to control this with a existing client application?
eg. an OPI client like cs-studio?  I find that questions like this
are best approached by think from the prospective of a client.
What will a client want to do?  What steps are involved?
Are there any issues of atomicity (eg. racing with other
clients).  What configuration will a client need?
Now for the part for which I have a clear answer.
For the present the 'field=' syntax is limited to scalars and arrays of scalars.
It is possible to send an array of structures w/ pvput provided you're
building against Base >=3.15 (which includes a JSON parser).  The syntax
is awkward though:
> $ pvput -h 2>&1|grep JSON
>  JSON support is present
> Field values may be given with JSON syntax.
An empty array:
> pvput test:Monit:localhost '{"services":[]}'
One element with all default values.
> pvput test:Monit:localhost '{"services":[{}]}'
One element with one field having a non-default value.
> pvput test:Monit:localhost '{"services":[{"state":42}]}'
Nested PVStructureArray With pvput William Cork via Tech-talk
Re: Nested PVStructureArray With pvput Michael Davidsaver via Tech-talk
Prev: Re: Nested PVStructureArray With pvput Michael Davidsaver via Tech-talk
Next: RE: ADpython issues with openCV sandeep-kumar.malu--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
ANJ, 03 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
