1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Somebody using PROFINET?
From: laurent daudin via Tech-talk <[email protected]>
To: "Penning, Joerg" <[email protected]>, [email protected]
Date: Fri, 12 Apr 2019 14:07:36 +0200
Hi Joerg,
We are here using PROFINET with MRP (Media Redundancy Protocol) ring to connect Siemens S7-1500 PLCs with multiple ET200S (distributed Inputs/outputs) for the SPIRAL2/DESIR beamlines and setup developments.
These PLCs are used for Vacuum, Interlocks, Insertion devices (FCup, BPM), Slits Motorization, ...
This MRP ring with Profinet protocol is a "field bus" only used for the PLC : The PLC CPU manage itself this MRP Ring.
It is completely EPICS independent and uses the two Ethernet CPU Ports.
An additional Communication module (CM1542-1) is used with S7-1500 to allow the Ethernet Network connection of each PLC with EPICS IOCs (using MODBUS-TCP) and HMI on Touch-Pannel located closed to the PLC.
Kind Regards,
Laurent.
Le 11/04/2019 à 16:50, Penning, Joerg via Tech-talk a écrit :
does somebody make use of PROFINET on EPICS?
We found this paper focusing on redundancy with PROFINET:
  https://accelconf.web.cern.ch/AccelConf/ICALEPCS2015/papers/wepgf020.pdf
Are there other approaches?
Thanks!
Best regards,
Mit freundlichen Grüßen,
Jörg Penning
DESY - Deutsches Elektronen-Synchrotron
Ein Forschungszentrum der Helmholtz-Gemeinschaft
phone:  +49-40-8998-2741            Notkestr. 85
fax:    +49-40-8998-4388           22607 Hamburg
e-mail: [email protected]            Germany
Somebody using PROFINET? Penning, Joerg via Tech-talk
Prev: Re: Somebody using PROFINET? Florian Feldbauer via Tech-talk
Next: areaDetector ADSupport R1-7 released Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Callback error from pyepics and python with GUI development Tong Zhang via Tech-talk
ANJ, 12 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
