1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: A call to 'assert(dbLockIsInitialized)' by thread '_main_'
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Iain Marcuson <[email protected]>
Date: Thu, 25 Apr 2019 13:16:56 -0700
dbGetField() can't be used prior to iocInit().
If you have to touch records at this point (which seems unusual for a driver)
then dbPutString() is the way to go.
On 4/25/19 1:14 PM, Iain Marcuson via Tech-talk wrote:
> I am writing a driver for a camera we have developed.  Part of the scheme involves monitoring a PV at about 20 Hz to check for a trigger.  I get this message on trying to read the PV.  I tried an initial read in the main thread to capture the problem before too much else was started.
>     by thread '_main_' failed in ../../../src/ioc/db/dbLock.c line 246.
> Dumping a stack trace of thread '_main_':
> [    0x7fcec9b5334b]: /home/iainm/local/opt/epics/base/lib/linux-x86_64/libCom.so.3.15.4(epicsStackTrace+0x4b)
> [    0x7fcec9b4c8ca]: /home/iainm/local/opt/epics/base/lib/linux-x86_64/libCom.so.3.15.4(epicsAssert+0x4a)
> [    0x7fcec9d9cdb2]: /home/iainm/local/opt/epics/base/lib/linux-x86_64/libdbCore.so.3.15.4(dbScanLock+0x1f2)
> [    0x7fcec9d9f45c]: /home/iainm/local/opt/epics/base/lib/linux-x86_64/libdbCore.so.3.15.4(dbGetField+0x2c)
> [          0x40dbef]: ../../bin/linux-x86_64/HPE3631Atest(_ZN10SpectroCCDC2EPKcS1_imiiS1_+0x74f)
> [          0x40de82]: ../../bin/linux-x86_64/HPE3631Atest(_ZL14configCallFuncPK11iocshArgBuf+0x62)
> [    0x7fcec9b3efb0]: /home/iainm/local/opt/epics/base/lib/linux-x86_64/libCom.so.3.15.4(iocshBody+0xae0)
> [          0x40c3b2]: ../../bin/linux-x86_64/HPE3631Atest(main+0x12)
> [    0x7fcec9249f45]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)
> [          0x40c3fd]: ../../bin/linux-x86_64/HPE3631Atest(_start+0x29)
> EPICS Release EPICS R3.15.4 $Date: Fri 2016-05-27 08:54:04 +0200$.
> Local time is 2019-04-25 13:01:39.451503845 PDT
> Please E-mail this message to the author or to [email protected] <mailto:[email protected]>
> The record in question is
> record(longin, "$(P)$(R)Cmd_GET_HW_TRIG_DR0")
> And the reading code is
> pv_opts = 0;
> pv_nreq = 1;
> dbGetField(&hw_trigger_addr_, DBR_LONG, &pv_val,
>                      &pv_opts, &pv_nreq, NULL);
> pv_val, pv_opts, and pv_nreq are of type long, as in other parts of the code that work.
> What might I do or look up to solve this problem?
> Thank you,
> Iain.
RE: A call to 'assert(dbLockIsInitialized)' by thread '_main_' Iain Marcuson via Tech-talk
Prev: A call to 'assert(dbLockIsInitialized)' by thread '_main_' Iain Marcuson via Tech-talk
Next: RE: A call to 'assert(dbLockIsInitialized)' by thread '_main_' Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 25 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
