1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Caput.exe of CaLab was not a valid programe
From: Freddie Akeroyd - UKRI STFC via Tech-talk <[email protected]>
To: 网易邮件中心 <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 1 May 2019 17:03:59 +0000
The download page for caLab doesn’t mention Windows XP, just Windows 7 and 10. If caLab was compiled on Windows 7 it will likely not work on Windows XP unless the Windows XP platform toolset (v90) was used rather than the default. I think Visual Studio 2010 may include v90 by default, in other visual studio versions you may need to add support separately e.g. https://docs.microsoft.com/en-us/cpp/build/configuring-programs-for-windows-xp?view=vs-2015
If you are not able to recompile the caLab DLL from the source download, drop me an email and I’ll see if I can help out
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of ?????? via Tech-talk
Sent: 01 May 2019 14:25
To: [email protected]; [email protected]
Subject: Caput.exe of CaLab was not a valid programe
Hi Carsten and others,
I downloaded CaLab V1.6.0.10( 32 bit) -----Setup for Windows© and LabVIEW™ 8.5 32 bit and higher (source code included) V1.6.0.10  (no separate EPICScomponents required) JUN 2018.
    But when I run StartDemo.bat, I was told "softIOC.exe was not a valid Win32 program" , "caput.exe was not a valid Win32 program".
   Then I tried the old version for labview7.0. It worked well but it didn't have the private file, which I need.
   And I saw the path, I think they both were good.
   I doubt the point was the OS, not sure.
   Could someone tell me how to do it.
Thank you,
Li Xing
My pc OS name: Microsoft Windows XP Professional
OS version: 5.1.2600 Service Pack 3 Build 2600 cpu: [01]: x86 Family 6 Model 58 Stepping 9 GenuineIntel ~3392 Mhz
Labview: 32 bit of 2012.
Re: Caput.exe of CaLab was not a valid programe Carsten Winkler via Tech-talk
Caput.exe of CaLab was not a valid programe 网易邮件中心 via Tech-talk
Prev: Caput.exe of CaLab was not a valid programe 网易邮件中心 via Tech-talk
Next: Archiver Appliance installation on Debian 9 Flaks, Leonid via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Caput.exe of CaLab was not a valid programe Carsten Winkler via Tech-talk
ANJ, 02 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
