1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with NSLS2 Debian repository?
From: "tom.cobb--- via Tech-talk" <[email protected]>
To: "Flaks, Leonid" <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 2 May 2019 12:37:16 +0000
We have some Travis builds that are using the NSLS2 Debian repository. They used to work before the repo moved, and now they are failing.
The snippet from .travis.yaml:
addons:
  apt:
    sources:
      - sourceline: 'deb https://epics.nsls2.bnl.gov/debian/ wheezy main contrib'
        key_url: 'https://epics.nsls2.bnl.gov/debian/repo-key.pub'
    packages:
      - epics-dev
      - build-essential
Tries to run:
curl -sSL "https://epics.nsls2.bnl.gov/debian/repo-key.pub";
Which fails with:
curl: (60) Peer's Certificate issuer is not recognized.
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
 of Certificate Authority (CA) public keys (CA certs). If the default
 bundle file isn't adequate, you can specify an alternate file
 using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
 the bundle, the certificate verification probably failed due to a
 problem with the certificate (it might be expired, or the name might
 not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
 the -k (or --insecure) option.
Any ideas?
Tom
> -----Original Message-----
> From: [email protected] <[email protected]> On
> Behalf Of Flaks, Leonid via Tech-talk
> Sent: 01 May 2019 20:33
> To: Mark Rivers <[email protected]>; '[email protected]' <tech-
> [email protected]>
> Subject: Re: Problem with NSLS2 Debian repository?
> The directory structure has been reverted back to original state. Now the link
> https://epics.nsls2.bnl.gov/debian/repo-key.pub works again.
> Leon
> From: Mark Rivers <[email protected]>
> Date: Monday, April 1, 2019 at 7:35 PM
> To: Leonid Flaks <[email protected]>, "'[email protected]'" <tech-
> [email protected]>
> Thanks, that fixed it.  Is that likely to be the path in the future, or are you
> going to ask them to change it back?
> Mark
> From: Flaks, Leonid <[email protected]>
> Sent: Monday, April 1, 2019 6:23 PM
> [email protected]>
> Our ITD is playing games with us. Long story short - they changed root
> directory (we asked them not to!). Now we need to drop the word “debian”
> from the path and all instructions that mention the path.
> Correct path for now would look like this:
> https://epics.nsls2.bnl.gov/repo-key.pub
> Thanks for noticing!
> Leon
> Get Outlook for iOS <https://aka.ms/o0ukef>
> ________________________________
> From: [email protected] <mailto:tech-talk-
> [email protected]>  <[email protected] <mailto:tech-talk-
> [email protected]> > on behalf of Mark Rivers via Tech-talk <tech-
> [email protected] <mailto:[email protected]> >
> Sent: Monday, April 1, 2019 6:37:52 PM
> To: '[email protected]'
> Subject: Problem with NSLS2 Debian repository?
> The asyn Travis build failed with the following error:
> 0.23s$ curl https://epics.nsls2.bnl.gov/debian/repo-key.pub
> <https://epics.nsls2.bnl.gov/debian/repo-key.pub>  | sudo apt-key add -
> gpg: no valid OpenPGP data found.
> The command "curl https://epics.nsls2.bnl.gov/debian/repo-key.pub
> <https://epics.nsls2.bnl.gov/debian/repo-key.pub>  | sudo apt-key add -"
> failed and exited with 2 during .
> Anyone know what is wrong?
> Thanks,
> Mark
Re: Problem with NSLS2 Debian repository? Flaks, Leonid via Tech-talk
Problem with NSLS2 Debian repository? Mark Rivers via Tech-talk
RE: Problem with NSLS2 Debian repository? Mark Rivers via Tech-talk
Prev: Re: IOClog Jeong Han Lee via Tech-talk
Next: Re: Problem with NSLS2 Debian repository? Flaks, Leonid via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with NSLS2 Debian repository? Flaks, Leonid via Tech-talk
ANJ, 02 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
