Hi Hinko,
> The reason is that I use `make install >/dev/null` no to see all the cruft during compilation, but only errors/warnings.
> The output of `convertRelease.pl checkRelease` is on stdout hence not seen in my case. I would like to see it though..
I am not disagreeing with you, but I think there is already another way to achieve what you want.
Rather than this:
do this:
make -s install
If you do that you will only see errors/warnings, but you will still see the messages from checkRelease. I just tested that.
From: [email protected] <[email protected]> on behalf of Hinko Kocevar via Tech-talk <[email protected]>
Sent: Wednesday, May 8, 2019 7:19 AM
To: [email protected]
Subject: convertRelease.pl checkRelease printing on stdout vs. stderr
Would the messages from `convertRelease.pl checkRelease` be better off seen on the stderr, as opposed to stdout? I think that is what I'm seeing on Linux builds.
The reason is that I use `make install >/dev/null` no to see all the cruft during compilation, but only errors/warnings. The output of `convertRelease.pl checkRelease` is on stdout hence not seen in my case. I would like to see it though..
All the text between 'Definition of..' and 'make[2]: *** [checkRelease] Error 1' is on stdout:
make -C ./configure install
make[1]: Entering directory `/home/gitlab-runner/bde/R3.15.5/bpmioc-mebt/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[2]: Entering directory `/home/gitlab-runner/bde/R3.15.5/bpmioc-mebt/configure/O.linux-x86_64'
perl -CSD /opt/bde/R3.15.5/artifacts/epics-base-R3.15.5/bin/linux-x86_64/convertRelease.pl checkRelease
Definition of ADSUPPORT conflicts with IOCAPP support.
In this application a RELEASE file defines
ADSUPPORT = /opt/bde/R3.15.5/artifacts/adsupport-master
but IOCAPP at /opt/bde/R3.15.5/artifacts/bpmapp-mebt defines
ADSUPPORT = /opt/bde/R3.15.5/artifacts/adsupport-R1-4
Definition of ADSIS8300 conflicts with IOCAPP support.
ADSIS8300 = /opt/bde/R3.15.5/artifacts/adsis8300-bpm
ADSIS8300 = /opt/bde/R3.15.5/artifacts/adsis8300-master
Definition of ASYN conflicts with IOCAPP support.
ASYN = /opt/bde/R3.15.5/artifacts/asyn-master
ASYN = /opt/bde/R3.15.5/artifacts/asyn-R4-33
Definition of ADSUPPORT conflicts with BPMAPP support.
but BPMAPP at /opt/bde/R3.15.5/artifacts/bpmapp-mebt defines
Definition of ADSIS8300 conflicts with BPMAPP support.
Definition of ASYN conflicts with BPMAPP support.
make[2]: Leaving directory `/home/gitlab-runner/bde/R3.15.5/bpmioc-mebt/configure/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/gitlab-runner/bde/R3.15.5/bpmioc-mebt/configure'
make: *** [configure.install] Error 2
Hinko Kocevar
Beam Diagnostics Engineer
European Spallation Source ERIC
P.O Box 176, SE-221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, SE-224 84 Lund
, Sweden
Mobile: +46-721-79 22 58
Phone: +46-46-888 32 58
E-mail: [email protected]
Web: www.esss.se<http://www.esss.se>
- Re: convertRelease.pl checkRelease printing on stdout vs. stderr Hinko Kocevar via Tech-talk
- convertRelease.pl checkRelease printing on stdout vs. stderr Hinko Kocevar via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
